Pics of your midbikes
Top Speed & Mods to get there
x7 top speed!!
a-nuter motor swap
Put down your top speed
Video
Midbike FAQ
Old 12-11-2004   #1
Question Can't Keep It Running!!!!!!!!!!!!!!
49cc R6 bike. I have just got done installing all my new parts: headstrong kit, stage two kit, 60 tooth sprocket, rocket key. i cant seem to get the darn thing running good. i took it for a ride and got it up to about 45 MPH. went back to the house and let the bike sit for a minute, while running, and then went to take it for another ride. had it opened up all the way and could not get over five MPH. it seems to be bogging down. Is this because i don't have it tuned right?
dadyfatsacs25 is offline   Reply With Quote
Old 12-11-2004   #2
zero4's Avatar
moved to midbike forum
Old 12-11-2004   #3
Outlaw50's Avatar
Sounds like you might be overheating it,do you let it idle for long periods of time? its going to get hot during the break in period,you need to heat cycle it a couple time brfore it will loosen up.I wouldnt let it idle for long amounts of time either,they need air moving through the fins of the motor to keep em cooled.
Outlaw50 is offline   Reply With Quote
Old 12-11-2004   #4
blah's Avatar
stage two kit? what's that? rocket key's and high compression engines are not a good combo, now that you have a higher compression and a better shaped combustion chamber, the combustion flame speeds up enough already. The rocket key is just too much, either sell it or see how far it can fly. Another area you should check is the head stud/screw tension, they need to be red tightened after a bit cause the become loose.
Also your jetting would be all over the place, in cases like these it's best to start too rich and work lean, that's the safest advice i can give over a forum anyway.
Old 12-13-2004   #5
i have the same bike..and had the same problem. embarassingly enough...my carb was loose from when i installed my air filter and vstack. i thought i had it all tight and had added some washers so the screw would tighten all the way down, but i just had to retighten them after a few rides. i also had lightend my CVT, and put one of the weights back in, because the whole wide up and not going, seemed like the CVT was slipping.
kyzer is offline   Reply With Quote
Old 12-13-2004   #6
dmljohnson's Avatar
sounds like a carb problem to me also....
dmljohnson is offline   Reply With Quote
Old 12-13-2004   #7
I have the same prob but I think he hit it right with the rocket key is too much for it after the headstrong kit but I know longer have my stock key. any one want to trade?
cagkiller is offline   Reply With Quote
Old 12-13-2004   #8
dmljohnson's Avatar
quick question..........guys isnt rocket keys for advance timming, gives you buttom end power............right..
Old 12-13-2004   #9
Thumbs up
yes!......
Old 12-13-2004   #10
dmljohnson's Avatar
Originally Posted by cagkiller
yes!......
so why will it be too much for the bike.....bogging is normall cause by the fuel mixture not being right............unless i am wrong....
Old 12-15-2004   #11
I noticed a bolt lose on the head. I'm not sure but i think i might have blown the head gaskit.
Old 12-15-2004   #12
blah's Avatar
Talking
Yes, fuel mixture can cause bogging, so can laxitives
The rocket key advances timing,right?
With a high compression central dome head you pack extra fuel/air into a tighter area under a greater pressure with less distance for the flame to travel, this has a similar effect as advancing the timing, it takes less time for the fuel/air to burn, right?
Now imagine if you had both, the gasses would be combusting too early causing some serious heat and pressure, you'd hear strange knocking noises As the piston tries to go up but is forced down and slaped against the bores, you'd get extra heat and no doubt the pressure would probably stretch or pull the head bolts out....btw what cause the bogging??
*Early spark make bang early
*Faster fire make bang early
*Faster fire and Early spark make engine go bang bang!
Old 12-15-2004   #13
blah's Avatar
also, read this thread:
Oh NO! Power Fade! Help Please!
got the bike running and it SNOWED!! blueR1cag Air Cooled Pocketbikes 0 01-15-2005 08:30 PM
x1 running problem bazza 2Stroke Midbikes 6 01-09-2005 08:19 AM
Pocketbike doesn't stay running parteboi206 2Stroke Midbikes 7 11-15-2004 06:13 PM
some questions for you guys running ported zh-1 barrels >>> TYSTYX Air Cooled Pocketbikes 4 11-14-2004 09:48 PM
pb planet running slow gopeder123 Problems, Suggestions & Bug Reports 7 09-18-2004 01:10 PM
Page generated in 0.35047 seconds with 54 queries
