ok so i finally got everything wired right and found out that i do in fact have a Z600 w/ 49cc, everything has been good untill a few days ago...
i went outside to fire up and ride the bike for a bit and got a surprise, when i push the primer bulb to prime it, i no longer get a steady flow of fuel throught the return line, just lots of air bubble filled fuel, so i checked all the lines and theyre all good no leaks or cracks, and now when it runs it will only run with the choke on then when i hit the gas i have to shut the choke off, then choke it when i come to a stop so it will idle
i then took the carb off, cleaned it out real good, cleaned the filter, screen, and checked for leaks around the intake manifold, all was good so i replaced evrything with new gaskets put it back together and im still getting the same thing......ive got the mixture screw set at 2-1/2 turns out, ive tried richening it and leaning it out but no change
Help im stumped and getting a bit frustrated
sorry for the long post but i figured a very good description on what it was exactly doin would make it easier on everyones diagnoses on what could be wrong
thanks in advance for any help
