Pics of your midbikes
Top Speed & Mods to get there
x7 top speed!!
a-nuter motor swap
Put down your top speed
Video
Midbike FAQ
Old 08-25-2004   #1
cateyes is not starting
i was out for a ride on it like 3 days ago. it was running fine adn my idle sucks so if i let of it will shut off. so i was making a turn and i let down on throtle to long so it turned off. the electric start ant working ether so i tried to pull start nothing. i try lik every day and nothing.
the only thing i know is when i used to pull start with throtle high it would make a deep low pitched sound.............but now when ever try to start with the throtel a little or alot it is always the same sound
could the carb be cloged, spark pug or am i screwed
i need help
hahaha is offline   Reply With Quote
Old 08-25-2004   #2
rnbsoulchild's Avatar
to start the electric way...you gotta hold down the rear brake lever...add some gas..but dont flood...n push the yellow electric start buttom located on the right side under the throttle...if you didnt know that already lol
rnbsoulchild is offline   Reply With Quote
Old 08-25-2004   #3
thats how i used to do it but that stoped working when my bike ran out if charge cause now it wont charge
i dont get these thing running great one sec and the next sec it is broken
Old 08-26-2004   #4
if it doesn't do anything and keeps basicly the same noise and when you give it more gas it just gets deeper you need a new plug. YOu probly have no spark. once you get it to run turn the carb up all the way and just back it off untill it almost dies then turn it back just a little and it should idle.
Se7en is offline   Reply With Quote
Old 08-26-2004   #5
so it should be my spark plug ok got it cheap fix.
ya i know my idle stinks cause the screw fex out
thank for the help every one
Old 08-26-2004   #6
iDR07's Avatar
about the idle, just buy a screw at a local store...
try cleaning the spark plug b4 u buy a new 1, unless u really want to upgrade...
wait forget it, just upgrade to a better sparlplug...
iDR07 is offline   Reply With Quote
Old 08-26-2004   #7
sesshoumaru562's Avatar
If the bike doesnt start check for 1. Spark 2. fuel 3. air leaks
In general these bikes usually suffer from fuel delivery paroblems or airleaks. Air leaks can be identfied by spraying carb cleaner around the carb area. If The bike suddenly starts then its an air leak. Also using carb cleaner to spray into the carb helps the bike start right up too. Also check the spark. Sometimes the spark will be bad if the cyclinder is flooded with gas.
Cateyes - X-7 gagt2nv 2Stroke Midbikes 15 03-28-2005 09:48 AM
Problems Starting Cateye!! Pleez Help Noob!!! mp5niper56 2Stroke Midbikes 23 12-24-2004 03:53 PM
Cateyes Chain problem and other small mods I have done AFallsBiker 2Stroke Midbikes 2 10-18-2004 04:27 PM
CVT Trans for Cateyes? Spades 2Stroke Midbikes 11 09-30-2004 07:33 PM
reasons for hard starting ? Vision Air Cooled Pocketbikes 6 09-02-2004 09:13 PM
Page generated in 0.20943 seconds with 36 queries
