Pics of your midbikes
Top Speed & Mods to get there
x7 top speed!!
a-nuter motor swap
Put down your top speed
Video
Midbike FAQ
Old 03-07-2005   #1
Kingjsa's Avatar
Compression, PSI to Ratio conversion?
Hey guys,
I have an X1 with the 43cc engine. Does anyone know what the convesion from psi to compression ratio is. I am showing 138psi on my gauge. What does that convert to.
I am looking to get 13:1. Does anyone know how many psi that would be?
Kingjsa is offline   Reply With Quote
Old 03-08-2005   #2
www.extreme4strokes.com
sorry but that is not how it works at all. 13:1 is impossible on a 2 stroke unless you are measuring static compression but the accurate way to measure the 2 strokes compression ratio is from the time that the piston passes the exhaust port. That is the way most manufacturers measure it which is why most literature on 2 stroke bikes will specify a compression ratio of 6.5-1 up to 8-1. 138psi is pretty high if your motor is stock and your gauge is accurate, try someone else's compression tester to see if you get the same high result.
Old 03-08-2005   #3
Kingjsa's Avatar
Hey Bart,
I tried another tester and I got 90psi, but was having trouble getting a good seal because it was longer than the other one and was hard to get in there. I was showing 119psi befor I took the engine apart. When I put it together I did not use a gasket so the comp should have raised a little.
Also this site sells a 13:1 that runs on 93 octane. http://www.pocketbike-warehouse.com/...tml&lang=en-us I wanted to try to run the same comp on my stock little motor.
What I am trying to do is run the most compression possible with 93 octane. That is my goal. I am using 87 octane right now, and am worried that it is too low for the comp I have.
Old 03-08-2005   #4
Compression testers are only good for a ballpark figure or to compare multi cylinder engines to see if they are even across the board. I have never had 2 testers read the same thing but I never had a very expensive one either, I typically get readings of 90-100 on stock motors with my tester. The 13:1 ratio is not very accurate but will certainly be higher than stock, you want to find a dome with a wide squish band and a central spark plug to be able to run lower octane with high compression. The spark plug location stock will certainly detonate with low octane but a centrally located spark plug with a wide squish band dome will tolerate less octane with higher compression, you may be able to go even higher compression on 93 octane if you set it up right.
Old 03-08-2005   #5
Kingjsa's Avatar
I didnt think the tester would give an accurate reading, though I can see how the compression changes. That way I can see the difference. By the way. I noticed absolutely no difference in speed from the 120 psi to the 140psi. I will let you know if changing my fuel will help.
Spec Update for Banshee SHO W/C Pocketbike scooterteq Water Cooled Pocketbikes 21 01-18-2008 12:57 PM
Stock Blata engine compression ratio Marto European Pocketbikes 0 02-23-2005 06:58 PM
Cag heads and compression ratio gulliver22 Air Cooled Pocketbikes 28 01-05-2005 11:22 PM
compression ratio polarice7 Air Cooled Pocketbikes 9 08-31-2004 04:33 PM
Page generated in 0.22191 seconds with 30 queries
