Pics of your midbikes
Top Speed & Mods to get there
x7 top speed!!
a-nuter motor swap
Put down your top speed
Video
Midbike FAQ
Old 06-03-2005   #1
60cent's Avatar
crash
today i was riding my pocket bike and i hit a bump,the chain snaped off,and i flew over the wind sheild and the bike fell over to the right breaking the brake lever.What caused my chain to pop off?
60cent is offline   Reply With Quote
Old 06-03-2005   #2
MelloCag's Avatar
chain tension possibly to tight, not lubed properly, or just unfortunate
What happened to you is the classic highside and you are lucky you did not brake a collar bone as most do getting flicked over the bars.
Old 06-03-2005   #3
60cent's Avatar
luckily i wasn't going that fast but i still got a couple off scraps,i think my bike took the most damage
Old 06-07-2005   #4
Sorry to hear that. I agree chain being to tight and chain being to loose is a posibility
wthreez is offline   Reply With Quote
Old 06-16-2005   #5
Wrath7sins's Avatar
I would also check your axle alignment. Adjust the chain-side axle jack until you reach the desired chain tension, tighten the axle nut on that side. Now tighten/loosen the other axle jack while you spin the rear wheel and watch the chain riding on the rear sprocket. When the chain rides center on the sprocket, tighten the axle nut. With both axle nuts tight, check the axle jacks to make sure they are snug, but not too tight. Keep in mind that proper chain alignment may cause your bike to crabwalk slightly, or it may fix a crabwalk you already have. Either way, be ready for a change in handling just in case.
You can't rely on distance from the end of the slot or end of swingarm since these things are all made differently, with varying specifications and manufacturing tolerances.
Best tension for the chain: The middle of one side should be able to move up or down at least a half inch, but no more than 1". The chain will not move on the other side. It must not flop about loosely.
Wrath7sins is offline   Reply With Quote
Old 06-16-2005   #6
royboybmx's Avatar
i had a similar incident a few days ago, face planted over the bars and spent 3 days in the hospitol after surgery to my elbow "2 pins and wired back together", feel lucky!
royboybmx is offline   Reply With Quote
crash bobbins? 1shot1kill Air Cooled Pocketbikes 7 05-27-2005 11:19 PM
Crash species0113 CAPRA 3 05-23-2005 12:46 PM
rossini crash test RossiniF1 Air Cooled Pocketbikes 37 04-23-2005 10:36 AM
Bad Crash >>> TYSTYX Air Cooled Pocketbikes 11 03-18-2005 07:13 AM
wot crash!!! vtecds1 Air Cooled Pocketbikes 18 09-24-2004 04:05 AM
Page generated in 0.19487 seconds with 33 queries
