Hi, I like to build home scooters and such and am looking into buying a pocketbike cvt for one of my projects. The three cvts I have found thus far are the following three:
http://store.partsforscooters.com/trans-cvt.html http://www.scooterparts4less.com/web...ke_gearbox.htm http://www.scooterparts4less.com/web...ansmission.htm
Basicly I just want to know what kind of gear ratios those cvts produce, and if one is better then the others in terms of durability. Also, the third link I provided(the x1 cvt) I'm confused as to if that is a cvt or some other kind of transmission because it uses a chain rather then a v belt, so does the x1 transmission behave like the x1 cvt in terms of the constantly variable gear ratios? thanks
