| Re: gas lines to tank The black line is the feed line and the clear line is the return line so you can see when the carb is properly primed...Look inside the tank;-take a coat hanger and fish out the lines;-youll see a filter stone on the end of the black line that will be glazed,clogged or discintigrated that will need to be changed...the new fuellines can be gotten from your local mower repair shop aswell as the filter...Its the same fuelline/fuelfilters thats used on weedeaters and backpack blowers.The new lines get prebent with a heat gun to get the bends to conform without kinking plus the stone filter helps the line stay at the bottom of the tank too.....................Peace
