The kit is a pretty simple install. The throttle return springs I got with mine were too short so I picked up some from a local hardware. You will have to fab something to hang the pipe, as it wasn't a direct fit for either of my X1s. I just mounted the hanger that they give you right behind the seat rubbers and got a long stainless bolt and some nuts to hang the pipe from. I also used the short pipe adapter that came with the pipe, along with the stock header pipe. I agree that this would be the perfect time to add a boost bottle, which you can probably do for much less than described in this thread.
If you go to the "How To's" you will see a pic of how to modify your intake when adding a boost bottle. It's pretty easy, just need a small drill bit.
Originally Posted by energie23 where do u get this kit from? is there one for the cateyes? |
Either look up Oneillbrothersracing.com or go on
Ebay and search for "pocket bike exhaust". On
ebay most of their stuff has a red background in their pics.
