Pics of your midbikes
Top Speed & Mods to get there
x7 top speed!!
a-nuter motor swap
Put down your top speed
Video
Midbike FAQ
Old 09-28-2004   #41
Im Retro Fitting The Sprocket Of The Xr 50 To Fit ..so Hopefuly That Will Work Out For Me ..oh I Found A Guy To Do The Welding , He 's A Machinest, And He's Interested In The Swap ...so Mabey He'll Masage The Rest Of The Bike A Little..the Speedomiter Poles Repulsed Him , So We'll See.....an Don't Worry For Those Of You Out Their That Are Followin This ..my Camera Has A Vid Recorder ..so When I'm Done We,ll Watch A Run Or 2...AND I'LL TRY TO KEEP FRESH PICS!
P.s. But Only If Your Interested?.....:d
d-a-n is offline   Reply With Quote
Old 09-28-2004   #42
Dan, that's lookin awsome!
Your totally on the right track.You won't be ably to use the original sprocket that's bolted to your wheel though.(as you probably know).Go to your local motorcycle shop and ask them to ordet you a "blank sprocket" 420 pitch (honda xr 50).
and then all you have to do is drill it out for your wheel, no sweat.
And don't forget your gonna need linkage for your shifter, or flip it upside down, see how close it gets.
Any way looking good dude.
Heres one we just completed.
later
Jethro
jethro is offline   Reply With Quote
Old 09-28-2004   #43
As Promised
Old 09-28-2004   #44
Thanks Jethro ...i Tried To Post A Vid Of Rear Swing Arm Articulation Didn,t Work Any One Out Their Able To Help...thanks Agin Bin...lol
Old 09-28-2004   #45
Don't forget to check for clearance for the chain under the lower frame rail, I had to notch ours, and channel it.
Half the fun is getting there.
When you want to do your engine, let me know.My xr 50's pushing 90 kph's.
I let you in on some performance tips.
Jethro
Old 09-28-2004   #46
Talking
NoT To Sound Sentimental..,but That Means More To Me Than You,ll Ever Know ...i've Had A Blast So Far (monnster Garaging This Thing But It,s Time To Let The Pros Take Over Being I,m Not Using Any Plate At All Under The Engine For A More Trick Look , And The Xr 50 Mounts Ww/ A Bockbone Mounting Style.....IN OTHER WORDS THERES TWO BOLTS ON TOP AND BACK OF THE ENGINE
Old 09-28-2004   #47
Just 'cause you farm it out to the experts to have some work done is no big deal.We know it's all you..
anyway, too much posting, not enough banking is gonna **** my wife off..
later
Jethro
Old 09-28-2004   #48
Never The Less Apreciate It:d
Old 09-28-2004   #49
JETHRO WHAT GAGE CHANNEL DID YOU USE ON THE CROSS BAR ? ..THINK I'M GONNA HAVE A PROBLEM W/ THE CHAIN CLEARENCE
Old 09-29-2004   #50
I happen to work at a steel factory, so I was able to get rectangular tube, just like your main frame, anly thicker .095 to be exact.So it's real thick.
What I did for the chain though was this.
I totally removed the lower crossmember.Once it was gone it was replaced with the thicker crossmember.Once we knew where the chain was going to hit, a notch was cut into the crossmember.Now theres a hole half way through the member.we just cut another piece of tube in half and welded it into the hole.Now you have a channel in the crossmember, that should be welded solid, and doesn't interfere with the chain.
I'm going to the shop tonight, I'll snap some picts so can follow what I mean.Pictures worth a thousand words.
see what I can do.
Jethro
Old 09-29-2004   #51
Talking
SOUNDS GOOD .....CAN'T WAIT TO SEE PICS ...., AND YOUR RITE ...BEFORE THE BUILDS OVER , I WILL HAVE SPENT A THOUSAND OR MORE ,,,BUT I CONSIDER IT MONEY WELL SPENT...
Old 09-29-2004   #52
Playin With Carbon Fiber
Heres A Stock X-1 Pipe W/ Carbon Fiber Vynal Tape ....watcha Think!
Old 09-29-2004   #53
Syner's Avatar
Looks good d-a-n, but won't the tape melt?
Syner is offline   Reply With Quote
Old 09-29-2004   #54
I'm Noy Sure Actualy ...i Use It On My Nitro Pwrd. Rc. Cars Never Mels ..in Fact It Sticks Like Crazy ...i'll Keep You Posted ...it Was Just Something To Pass The Time Away..........bikes Still Not Welded ....waiting Patiently......
Old 09-30-2004   #55
got some more pics ill get them up tomarrow
Old 09-30-2004   #56
its a brand called orical found at local grafix company
Old 10-02-2004   #57
Talking
well ///i,m getting the bike back from the machinest , monday....my sprocket & chain comes in from the honda dealership , tuesday , and my fmf powercore 2 exaust w/ silencer comes in wendnesday.... i'm sutcha happy parent...
Old 10-02-2004   #58
BoostedBoogie's Avatar
**** now I want to do a swap.
BoostedBoogie is offline   Reply With Quote
Old 10-02-2004   #59
NOUSAGI's Avatar
ok ill open up....about Nousagi-X192...
im aswell doing a motor swap, was trying to stay hush-hush about the whole thing until i received the motor and did some pics to show and didnt wont to get ahead of my self but since this guys got yall all hyped i mightest well come out and say im in the process of installing a 192cc honda 5 speed -into my X2- i have most of all my mods in my head ready to get applied to the project (the plans are also drawn out w/notes) as far as the clutch,bearings, brakes, wiring, welding, chain and sprocket (oh-yea and a remodded gas pancake tank made of the same gas tank plastic) .. the bike is stipped & allready for the motor size-up,remod fame work .. i have some great ppl pitching into this project- in the mean while im gonna swap the x2 w/cvt motor into my cateyes --- so i could still ride something -- more info when the motor arrives will be here sometime this week....................................till then here comes cvt cateyes.....peace NOUSAGI
NOUSAGI is offline   Reply With Quote
Old 10-02-2004   #60
What's the motor out of dude?
DAN, sorry about the no pics, I forgot my camera at home, will get some though.Any questions feel free.
Jethro
Page generated in 0.34170 seconds with 76 queries
