Pics of your midbikes
Top Speed & Mods to get there
x7 top speed!!
a-nuter motor swap
Put down your top speed
Video
Midbike FAQ
Old 01-06-2005   #21
38 mph(done by car) mods: tuned carb, gears, drilled airbox, no exhaust
coming soon: rocket key, air filter w/v-stack, moded stock pipe, boost bottle, lightened flywheel, ported exaust, shaved head, (clutch spring & carb??? possibly)
wildyote is offline   Reply With Quote
Old 01-06-2005   #22
no exhaust
your pistons donefor
Old 01-06-2005   #23
Wink
Stock X7 running @ 34.5mph. It has no mods, just keyed in nicely.
X7Racer is offline   Reply With Quote
Old 01-06-2005   #24
u sucker just got served's Avatar
Arrow
35.6mph stock(after market hotwheels speedo) on my x7 i havent even had the time to take off the goveners yet!!!
u sucker just got served is offline   Reply With Quote
Old 01-06-2005   #25
1.8TurboS's Avatar
47.1 with a 6/68. Cag with polini 6.2. Radar gun + GPS.
1.8TurboS is offline   Reply With Quote
Old 01-06-2005   #26
I'm new to 2strokes, how does that ruin the piston, does it get to hot or sumthin? i have a spare motor in the garage should i take the piston from it?
Also are there governers on these things?
Originally Posted by sikksikksikk
no exhaust
Old 01-06-2005   #27
SSJDemon's Avatar
No, dirt will get into your piston from riding and destroy it.
Some of these bikes such as the X7 have governors and some dont. Do a search.
SSJDemon is offline   Reply With Quote
Old 01-07-2005   #28
52mph x2 the list is in the class section does this on a daily basics
fast one is offline   Reply With Quote
Old 01-07-2005   #29
TeamMacDaddy's Avatar
Originally Posted by fstbusa
52mph
polini 4.2, 7 tooth pinion.
52?? on a 4.2??? My A$$
TeamMacDaddy is offline   Reply With Quote
Old 01-07-2005   #30
blah's Avatar
52 from your A$$? that's a fast A$$
Old 01-07-2005   #31
52 thats fast
RevOv is offline   Reply With Quote
Old 01-07-2005   #32
moto-x-troy's Avatar
Thumbs up
47+ mph on a radar gun! I have seen over 10,800 rpms out of my sooo slow 49cc X2 engine with the Proline pipe! While driving at WOT the tach was reading 9,280 rpms under full load. This engine still has the stock carb on and the air filter is the only aftermarket mod.
I only.....
1-installed Air filter w/stack
2-cleaned up the ports some/windowed the piston
3-installed the Proline Racing pipe--30 min. including making new gaskets
4-tuned CVT----------------------hours of tunning
With only these 4 modifactions my X-2 (with CVT) is pulling these rpms running the stock gearing. Top speed has been measured at 47+mph. I know this is hard to believe but I have my own shop and do alot of tunning on my bikes to make them run as well as they do.
I will be testing a PBU Reed Inducted Engine on my bike with the 257 carb kit and new aadjustable stinger tip! This will tell how good my inhouse engine holds up to the PBU kit!
Troy
Troy Gansen
moto-x-troy is offline   Reply With Quote
Old 01-07-2005   #33
pswsheadkit with reed setup
porting for reed
cvt mod
sprockets
custom grips
fast tach
proline pipe
this bike runs 52mph comes with extras
pac sale pipe
For those who wanted to know!
Troy
Old 01-08-2005   #34
SSJDemon's Avatar
Unhappy
Originally Posted by moto-x-troy
I will be testing a new adjustable stinger tip!
It's amazing to me how much PBU's new pipe is just like my Rattlesnake pipe that's been on the market since Nov. of 2004. Proline is truly the only one that's had any new pipe ideas in the pocket bike industry! LMFAO
http://www.pocketbikeplanet.com/sho...ghlight=Proline
Old 01-08-2005   #35
ok ok .... at the time mods were dual reed setup, gearing and filter.
so I guess you could call it a 6.2 without the pipe. but it is originally a 4.2.
fstbusa is offline   Reply With Quote
Old 01-08-2005   #36
SSJDemon's Avatar
Crap, misquoted above.
Ill just repost
I will be testing a PBU new adjustable stinger tip!
Old 01-08-2005   #37
Who are you and what is a Rattlesnake pipe? If your talking about Prolines pipe I already have one and have a good relationship with Kirk at Proline. I just wanted to try PBU's new pipe. It is not a Go Ped pipe modified to fit an X2(which I like very much) but a new design in itself. I am not biased toward wither company but give each equal respect!
Troy
Old 01-08-2005   #38
SSJDemon's Avatar
Ok, got my bike tuned and up to 37.9 mph. Note the bike is not fine tuned, just roughly tuned
Old 01-14-2005   #39
top speed
40mph with juicebox, 15mm carb, vstack, air cleaner, jetpro exhaust, stiffer clutch spring. 190lbs.
Originally Posted by RevOv
put down your top speeds in mph, then put down your all your performance mods, Be honest. I wanna know what mods you think are the best and which ones you regret getting!
jeffdodson is offline   Reply With Quote
Old 01-15-2005   #40
stnt4ride7's Avatar
34.7 mph (according 2 a radar gun)
cat eye
only upgrade was
tuned carb
cvt
stnt4ride7 is offline   Reply With Quote
Top Speed & Mods to get there sesshoumaru562 2Stroke Midbikes 332 07-26-2009 11:33 AM
Top speed cabridge Air Cooled Pocketbikes 51 05-05-2008 09:46 AM
top speed bogging gurt Air Cooled Pocketbikes 17 04-22-2006 11:51 PM
cag top speed? u sucker just got served Air Cooled Pocketbikes 17 06-23-2005 07:06 PM
Page generated in 0.36811 seconds with 77 queries
