Cat eye 43-45mph using car & truck
Mods:
Engine 43cc
ADA Aluminum V-Stack & Fiter
23 tooth(front) & 36 tooth(rear) sprockets
Ported & Enlarged Intake and Exhaust runners (Machined piston skirt for exhaust port)
EBay Poop Pipe
Advanced Timing(with no key)
Stock Carb (tuned by me)
Homemade Boost Bottle
Clutch Spring Modifications
100:1 Synthetic Oil/Gas mixture
I am 5'-11" @ 214lbs
It takes some help to get started, but after the powerband kicks in, she flies!
This was done on a flat road.
I am replacing the 36 tooth sprocket with the stock one simply because if there is any incline of the road, it is hell to get up to speed. And that is if I can get up to speed. If I can reach the powerband, I'm OK, but if not, I'm S**T OUT OF LUCK!
