Originally Posted by shibby i run the lightweight clutch with the hot spring in my x7 works great it alows the clutch to slip long enough to get on the pipe kind of like the C1 or banshee |
Thanks for all the info it helps alot, but shibby where can I find the hot spring. What website can I order it from and how much is it? Also my engine is making a metal on metal noise and is somewhat hard to pullstart I cant figure out where it is coming from. Someone said it might be a broken clutch spring so I checked that and its fine. So what do you guys think it is? Thanks again for all the help.
