Originally Posted by x-7rider Alright well last night i got it started using a slightly larger battery that would actually spin the motor for more then 10 seconds at a time. It ran like crap basicly:P. It wont start with the pull start but im pretty sure with a little tuning i can change all that! Each time i let go of the throttle the rpms would lower to the point that it would just die and this is with the idle screw all the way in!. It didnt rev as high either but ill be doing some tuning once i get a new manifold because the brass inserts in mine slide out too easily not allowing me to tighten the carb completely. |
I had the same problem. My bike wouldnt stay idling, it would run but only above half throttle.
Sounds like you still have an air leak going on.
While its running spray some WD-40 around the intake and look for a reaction.
In order to use the aftermarket carbs you need to buy the adapter plate.
Such as this one
Walbro Intake adaptor for 49cc Mid bike
Hope this helps
