Originally Posted by dellbot |
if you had the dimensions of the filter i might be able to help, i run a prototype velocity stack i mad myself and use a k&n filter. the length of my filter is 78mm from the end of the filter to the end of the rubber mounting point. the filter is about 2mm away from the shock mount. The x7 did come with 2 differnt shock mounting positions. 1 the shock was mounted forward towards the motor. 2 the shock was mounted away from the motor. in this pic i have the forward mounted shock frame. also adding this filter did require me to remove the motor.
