Okay well i my X1 eletric starter isnt working. Everytime i try to start it, it would just buzz, and i charged the batt. I would also want to know how i know my ignition coil is still good. I just changed the spark and my pull cable just broke on me, so i have no idea motor even works still. and when i had it before, it would take me more than 25 pulls just to get it started. Can someone help?
Well it sounds like your going to need to get a pull starter so you can check for spark. Is the buzzing coming from the eletric starter or from under the gas tank? Than you should get a new spark plug and reset the carbs mixture screw to 2 1/2 turns out.
oh crap! haha thanks bro! i had the carbb mixture all the was turned out. well i changed the spark today. It was very black. um the buzzing is coming from under the gas tank. Its buzzing from the batt. circle. :P
hey is this site trustworthy?? :P um got anything else i can doo? also i don't think i have a choke. :P The buzzing in comming from next to the gas tank :P
Yes that site is trustworthy. They have been around for more than 4 years. I wouldn't send you to a site if it wasn't. Theres really not alot .you can do without a pullstarter or with a broken carb. You can take off the gas tank and hit the starter button and pin point the buzzing. I think it is the silinoid that is buzzing. What do yoummean you don't have a choke? Is your air box missing or is it broken? You should just get a V-stack with a choke and a airfilter.
well i got a v-stack but it came with no choke. well i just ordered the cable =] ahh um i think the buzzing in coming for the rubber black battery thing. if you know what im talkin bout =]
... well obviously the battery is functional ... it has a very low battery but you won't get the motor to turn over with such a low level of energy
get a new battery and get your bike started
