Pics of your midbikes
Top Speed & Mods to get there
x7 top speed!!
a-nuter motor swap
Put down your top speed
Video
Midbike FAQ
Old 11-19-2008   #1
x1 help
ok i just got a used x1. and everything works accept for the electric starter and taillights. but the only time the headlights work is when it is moving.... a so do i need new battery or what?
x15 masta is offline   Reply With Quote
Old 11-19-2008   #2
dragonkeep2000's Avatar
Re: x1 help
did you test your battery for voltage ? you may need a new starter relay or a wire may be dissconnected or cut somewhere....check all possibilities before just settling on buying a new battery............as for the tail-lights even with a bad battery while it is running they should all work unless they have blown out....they are only small l.e.d s anyways........but then again check the wiring
Old 11-19-2008   #3
Re: x1 help
thanks for the help. i checked the fuze cuz it acted like my x15 when the fuze blows but the fuze was fine. and i will try to check the wiring but these thing are a mess. i might just take it all out. will the motor work if i just take all the wiring out. and then after a while i just add headlights right to the batter and just have them turn on and off with a little switch on the side or something.
Old 11-19-2008   #4
SPB Mod Master
Re: x1 help
If the lights wont work unless the bikes running means the battery is shot.......The battery could of cooked from the starter being bad...........Out of all my X-1's only 2 e-starters work. On the rest the e-starter wont crank the engine but they charge the battery and run the lights when the bikes running.Below is a schematic for the wiring.I find that on all my X-1's the cheesy turn signals burn out fast from vibration;-check the wiring with a light tester or digital multimeter...........Peace
File Type: gif X-1_harley bike_ cateye wiring harness.gif (69.4 KB, 87 views)
Old 11-19-2008   #5
Re: x1 help
thanks man that diagram thing is useful. but how do you think it sounds if i just take all the wiring out and then get new battery. and just make my own headlights. just by 2 wires going directly to the battery and a switch attached to them for on and off. oh and can i start it without a key? cuz my other motor just like that starts fine and there is no wiring at all
oh and is there any speed governors on the x2
Old 11-19-2008   #6
SPB Mod Master
Re: x1 help
You have to leave the solenoid and the voltage regulator.......The power coming from the alternator is a/c powered and transferred to D/C current through the regulator.........................if you hook the starter wire direct to the battery and start the bike the a/c back feed will explode the d/c battery unless you use an interupt switch but the battery wont charge.............
You can make a smaller harness with a regulator and wires coming from the solenoid to the starter button on the throttle;-use a toggle for the lights and a toggle switch for the ignition button power switch............this way you can start the bike;charge the battery and run the lighting.....................Peace
Old 11-19-2008   #7
SPB Mod Master
Re: x1 help
you can start it without a key..................in the ignition switch harness theres two orange wires and a black with white stripe and green wires;- 4 wires.............the two oranges are the power so the charging system and the e-starter will activate.........................the black and green wires are the killswitch wires...........................when the keys turned on it bridges the connection for the two oranges to transfer the power...............when the switch it turned off it breaks the orange wire connects and bridges the black and green to ground the coil and kill the engine.................
You know that you have to squeeze the left side brake handle when e-starting bike with the stock harness.......right?............Peace
Old 11-19-2008   #8
Re: x1 help
hahaha no i didnt know that!! ill go try to start it. but is it normal for no electronics to work unless it is running?
one more question. how do i take apart the forks. cuz they squeaky.
Old 11-19-2008   #9
Re: x1 help
ok just tested it electric start no work. also like when i turn the choke off it the choke lever is acting like a throttle... cuz when choke is on it idles good and not to high. but when choke is off it idles really high and the tire starts going.
Old 11-19-2008   #10
SPB Mod Master
Re: x1 help
The engine is running too lean or theres an airleak at the manifold or carb.............try turning the a/f screw out 1 turn and see what it does.If it didnt get better try a little more if no luck look for an airleak.......you may need to replace the intank fuel filter and clean out the filter sediment from the carb body strainer.................Peace
Old 11-19-2008   #11
nonoftheabove2008's Avatar
Re: x1 help
i have a question...
kinda on topic..........
i disconected the relay to try on another bike, now that i put a new engine in my x1....my friend is the dude that took it off ,,, and forgot what wires went where...
4 mystery wires...
1) red wire directly from bat
2) black wire from bat
3) yellow wire going to some connector "regulator?"
4) starter wire.
ok, looking at the relay, the ign switch wires going to the bottom of the relay... the left post of the relay would be hot?
right side being ground?
nonoftheabove2008 is offline   Reply With Quote
Old 11-20-2008   #12
Re: x1 help
i am terrible with wiring but try looking at the like diagram that cam2 posted
Old 11-20-2008   #13
SPB Mod Master
Re: x1 help
The solenoid is a relay...................it relays the battery power through it with a contact switch thats externally controlled by a seperate power circuit to activate the solenoid to turn the starter..................
one side of the solenoid contact screws goes the battery...................
the battery negative goes to the engine and mount at the transmission screw.......
the yellow wire is the voltage sense wire................it goes with the starter wire on the second terminal on the solenoid.....................Peace
Old 4 Weeks Ago   #14
Re: x1 help
HOW DO I CONNECT THE WIRES
mlan1234 is offline   Reply With Quote
Old 4 Weeks Ago   #15
Re: x1 help
How Do I Connect The Wires ?
Page generated in 0.29166 seconds with 61 queries
