Originally Posted by r3dfish On the ignition plug, coming off the coil, should there always be continuity? Every time I turn the key on when the ignition plug is plugged in, the fuse pops. I checked the continuity on the plug, and its always continuous. Is that the way its supposed to be? |
on a two stroke the only time the coil is hot is when the engine is cranking, the battery has nothing to do with the coil... My guess would be either the wires are crossed somewhere or there is a short in the wiring, most likely a short...
being it's an X1 check the wires at the headlights, they get bare where they go into the back of the light from rubbing against the housing and short out... Unplug all the lights and try it again, see if the fuse pops
