| Re: x1/x2 brake mount X1
The rear of the caliper bracket has a hole that axle bolt goes thru . If you look at the picture closely , the rear of the bracket does not sit directly against the swingarm . There are 2 washers on the axle bolt , that are inbetween the caliper bracket and the swingarm , to line it up evenly with the front part of bracket .
The front of the caliper bracket has a hole that bolts to a piece that is welded on the swingarm .
Bad pic. , but its the only close up pic. i have .
