Throttle
on my x2 has a delayed acceleration or at least feels like it. I want faster acceleration. My x1 accelerates pretty quick just wondering if i could tune them to best acceleration possible.
Carb tuning
what is the proper tuning for best speed. Every thing is stock.looking in to changing things just dont have money right now so any advice would be helpful.
Electric starters
I want the electric starters to work how do i go about checking whats wrong with them. Pull start works fine i can get both of them started. I know you hold the brake and push the button it just clicks and buzzes on my x2. My x1 bike i was told when i bought it off this guy said that the battery is dead so that could be a problem. when it is started up and i ride it around lights come one and are dim. I dont know if it is just the wires are mixed up or hooked up incorrectly?
Stock pipe is loud
I want to get my exhaust pipe to quiet down. I read another thread about doing something with steel wool. If someone could explain that again i am having trouble understanding it. O and would it help the sound if i drilled more holes in the exhaust. If i cant get this to work like i want it then i am better off buying a silencer of some sort. By any chance does the Rev-x1 silence it at all.
ok the steel wool thing is easy, all you do is take your silencer off and take out the insulation looking stuff in it, then you just put the steel wool where the stock insulation was
