Originally Posted by Williemonster As suggested I changed out the stock exhaust for an aftermarket in an attempt to get above the 35MPH mark. Ive retuned the stock carb to handle the new exhaust.
Posted elsewhere asking for suggestions about an aftermarket carb and was told to post here to get the correct answer. Im guessing the new exhaust will get me another 3-5 MPH with any luck but would like to reach at least 40 if possible without going nuts with bolt ons. Any suggestions concerning the carb or anything else would be appreciated. BTW, the bike if my grandsons, weighs about 60 pounds so IMO 40 MPH isnt really out of reach with the correct bolt ons.
Thanks in advance.
Bill |
Bill, 40 mph with just a pipe is pretty much out of the question... The stock carbs are junk so thats gonna hold you back alot..... The gearing should be changed....The cylinder will need ported and polished to let more air and fuel in and get rid of the exhaust faster..... Advancing the timing will help also...
Depending on what pipe you bought, I'm guessing the skinny, make sure that the header is match ported to the cylinder, most of the pipes including stock have a small inlet that covers half of the exhaust port thus causing alot of restriction and excessive back pressure...
Don't go by the stock speedo, they are wayyy off....
