| Re: X2 leaking You failed to tell us where on the carb its leaking.
If its where the float bowl meets the carb body, then a new oring, or depending on the carb, a new gasket will be needed.
But thats NOT what is causing your problem. Its a result of the problem.
Sounds like you have a piece of dirt in the carb float valve.
Also called a needle and seat.
A piece of crud gets between the needle and seat valve. It sticks open the carb float valve to flow fuel into the bowl.
The needle part of the needle and seat valve, is attached to the float in the float bowl. As fuel is allowed past the needle and seat it fills the float bowl. Once the float bowl is filled the 'float' pushs the needle into the seat and shuts the fuel flow off.
If dirt is lodged in the valve (it doesnt take much) it will cause the carb to 'over flow'.
Also, too high a float setting can cause the same problem.
If it was mine, Id take the carb off the bike, and check the needle and seat for debris, and check the float height.
A fuel shut off valve is a good idea on any bike. Its Safe. The bike cant dump its tank onto the floor if the valve is shut off.
If you have indeed a stuck fuel valve. Dont run the bike until you have drained and changed to oil. Fuel can get past the rings. Washing the lubrication from the cylinder walls.
It can also dilute the crank case oil. Which if used can cause bearing failure and cylinder scuffing. Finally, It's a Fire hazard.
Clean the carb. Check the float height, and change the oil.
Good luck!
