Originally Posted by StrayDawg63 You can get wave washers at a hardware store. You got the HP carb on now and not the stock carb? How did you get your speed or what speedo are you using? If your using a schwinn speedo than they only go to 34mph.
To tune the carb warm the motor and turn the idle up some. Now turn the L screw to the left until it starts to chuttering than turn the L screw to the right until the idle gets fast but keep turning to the right until it starts to chug than turn it back to left to where the idle gets fast smooth again listen carefully. Adjust the Idle to your liking. I like to adjust the idle by raising the rear wheel than adjust the idle until the back wheel starts to spin than I turn the idle down to just before the wheel start to spin which is just before the clutch engages. Now it's time to tune the H screw. Give it a ride to WOT and see hows she running. Than turn the H screw to the left a 1/8th turn ride again to WOT stop adjust a 1/8th ride to WOT and do this until it start to sputter at WOT or until the acceleration starts to suffer than turn it to the right a 1/8th of a turn. |
thanks right now i lost my idle screw
but ill go to the store get another as for the speedo its a bell from fred myers and its pretty accurate off by only 2 mph if that. right now it starts off fine and top end feels like its fuel cut its dying for more of something gas im assuming ill let you know how it goes
