Originally Posted by 2-stroke Mike Hi,
If you haven't charged the battery for almost one year I bet the bat is out.
A 12 volt lead battery should not be left uncharged for a long time.
When the voltage goes below about 10.5V the bat is hurt and may not survive.
If you connect a bat charger make shure it has a 1 amp current limit.
You can connect the charger between the fuse terminal and ground (frame)
/Mike |
Mike, thank you, but how do I connect it between the fuse terminal? The fuse is incased with a screw on top. If you could explain, or show pics that would be great.
Thx
