Pics of your midbikes
Top Speed & Mods to get there
x7 top speed!!
a-nuter motor swap
Put down your top speed
Video
Midbike FAQ
Old 10-16-2004
gelwalk's Avatar
this is how i got my numbers diameter NOT circumference
check my owners manual pictures this is the correct formula
example:
20 inch tire x 25.4=508mm x 3.1416=1,595.93 =1596 speedometer input
so! a
13 inch tire x 25.4=330.8mm x 3.1416=1,037.35=1037 speedometer input
  #22
Old 10-16-2004
My x2 max speed is 75.80 mph
  #23
Old 10-17-2004
gelwalk's Avatar
Talking
Originally Posted by gelwalk
MINE IS BONE STOCK WITH DIGITAL SPEEDOMETER RUNS 36.8mph, IM 180LBS,I WAS ALSO PACE BY MY WIFE ON MY TRUCK
13 INCH TIRE X 25.4=330.2 X 3.1416=(1037 SPEEDOMETER INPUT)
will install air filter with v stack,rocket key and ngk spark plug on tuesday will see if i can hit 40mph
  #24
Old 10-17-2004
40MPH!!!!
i was followed by a car today who told me my speed was 31 flat. which therefore actually makes the stock speedo somewhat accurate. since it was buried and it goes to 30.
I'm trying to get a solid set of instructions to bore out my carb. and trying to locate quality reeds and a full circle stroker crank for 49cc.
still stick between proline or pacsales pipe.
which air filter did you go with.
got the carb tuned to perfection now, amazing response and power throughout the powerband all stock as of now.
  #25
Old 10-17-2004
gelwalk's Avatar
Talking
THE ONLY THING THAT I HAVE DONE TO MY MOTOR WAS REMOVE THE SPARK PLUG SEAL. I WENT WITH THE ADA CONE FILTER. AND YES IM TRYNG TO HIT 40MPH WITH JUST ADD ONS
  #26
Old 10-17-2004
spark plug seal? i don't quite follow, could you elaborate, with words, or even better pics?
ADA, looking forward to a performance report
  #27
Old 10-17-2004
gelwalk's Avatar
Talking
TAKE YOURE S PLUG OFF AND IT HAS A SEAL RING JUST CUT IT OFF IT WILL INCREASE UR COMPRESION
  #28
Old 10-17-2004
I do not believe that really does enough to increase compression.....sounds like a myth to me.
  #29
Old 10-17-2004
gelwalk's Avatar
Talking
well i went from 32.1 to 36.8mph you can call it a myth but i see a big difference specially on the take off
  #30
Old 10-17-2004
did you get the ngk bpm7a?
i'm going for that one
  #31
Old 10-17-2004
gelwalk's Avatar
Talking
bm7a is the is the one i have
  #32
Old 10-18-2004
true ,true,true...i happened to get a pretty good bike from a batch with my friends and i was clocked at 34mph stock.which is not bad at all.all my friends do a respective 30 plus.there is one guy we ride with and he has the x2 completely hooked up(every add on you can buy) also tuned for the best bottom and top end.this guy is the only one that has a faster bike.but he can only get us all on the top end though......way at the top he passes us with ease.he runs 38mph top speed.heheheh.
Originally Posted by genesisautoworks
This is a great bike but,
the speedos are A joke...Just like the so called CVT in these bikes...the gear ratio in the gear box that alot of people think is a cvt is not bad though. the truth is that these bikes out the box( after removing the governer, yes aka speed limiter...factory installed if you have an aarvi manufactured bike ) is 25 to 30 mph. If you tune the carb right and break the motor in like you are supposed to then look forward to 30 mph. I need to get my digital cam working or buy a new one... I will take a pick of one of the shops project bikes reading 30 maxed out on the speedo with the gear box disengaged, the bike standing still. the reading comes from the motor not the rear wheel or gear box...
Sacramento!!! Elk Grove!!!
Check us out at the up coming Test n Tune event @ Genesis Autoworks, inc
BBQ
Parking Lot
Free tech help
and other PB enthusiasts
call the shop for details, 916.685.0062 talk to sid!
  #33
Old 10-20-2004
Originally Posted by PocketR6
My X7 does 33mph (tested with a GPS unit) on free mods- no air cleaner no throttle govenor, and tuned the stock carb a little- test done on level street, about 75deg. out, no wind, 175lb rider with a Garmin Streetpilot GPS. I would say impressive for this cheap thing!
Where is this "throttle governor"? Is it in the throttle itself? I've adjusted my cable at the carb and at the throttle, but haven't seen anything I would consider a "governeor".
  #34
Old 10-20-2004
asnboi512's Avatar
look at the top of the carb there should be two screws holding down a bracket, the on toward the back of the bike ( front of the carb ) should have another "L" shaped bracket on it with a screw threw it that hits the trottle when it is open, thats the govener or speed adjuster
  #35
Old 10-20-2004
BoostedBoogie's Avatar
do NOT remove that seal from your spark plug. moisture will get into the engine and you will be screwed. to effectively increase compression, just remove that washer on the spark plug and mount it back on.
  #36
Old 10-20-2004
gelwalk's Avatar
Talking
i believe that the seal and washer on a spark plug is the same thing
  #37
Old 10-20-2004
Thanks! Doesn't sound familiar, but maybe I missed something when I was adjusting the cable down there. I'll check this out tonight.
Also, I took the cover off the throttle and noticed there was a plastic piece up there that was limiting how far I could open the throttle at the grip. I think my use of a washer down on the carb end of the throttle was already allowing me to get as much pull as possible, but now I can take that washer out and use the throttle cable the way it was meant to be used. I sure hope I can find that bracket you are talking about!
  #38
Old 10-20-2004
Hey X7 owners, have you removed the throttle governer?
  #39
Old 10-21-2004
Well, I didn't have a screw up there that adjusts the speed, but there was an L shaped piece of plastic that was molded with the plate that sits on top of the carb that was keeping the cable from pulling as far as possible. Nothing a dremel couldn't handle though.
So I've now removed the plastic collar in the throttle itself and the plastic piece down on the top of the carb. That should take care of all of the governors/speed adjusters on the bike. The bike has really livened up after this. No idea what speed I'm getting yet though.
  #40
Old 10-21-2004
2oh6civic's Avatar
example:
so! a
Hey gelwalk are you using the bell speedo? amd if so how did you mount your magnet?
Top Speed & Mods to get there sesshoumaru562 2Stroke Midbikes 325 3 Days Ago 01:59 PM
Top speed cabridge Air Cooled Pocketbikes 51 05-05-2008 09:46 AM
top speed bogging gurt Air Cooled Pocketbikes 17 04-22-2006 11:51 PM
X7 Speed fmodesna8 2Stroke Midbikes 24 08-11-2005 10:53 AM
Page generated in 1.61220 seconds with 75 queries
