Pics of your midbikes
Top Speed & Mods to get there
x7 top speed!!
a-nuter motor swap
Put down your top speed
Video
Midbike FAQ
Old 09-19-2004   #1
XXXPERIENCE's Avatar
x7 top speed!!
Does anyone know the top speed of the x7??????????
XXXPERIENCE is offline   Reply With Quote
Old 09-19-2004   #2
sesshoumaru562's Avatar
about the same as any other midbike
Old 09-19-2004   #3
pimpcincy's Avatar
like 25 mph.
pimpcincy is offline   Reply With Quote
Old 09-21-2004   #4
Originally Posted by pimpcincy
like 25 mph.
are you serious? the one im gettin goes 45
Romes is offline   Reply With Quote
Old 09-21-2004   #5
pimpcincy's Avatar
all post on ebay and some other internet stores say 45 but thats just a way for you to buy their product. they said 45 for cateyes but those really go like 20-25 mph.
Old 09-21-2004   #6
Heh Heh Heh!
jonvall is offline   Reply With Quote
Old 09-21-2004   #7
good luck with it going 45! hope you have a lot of money and time to put into it
scubasteve82 is offline   Reply With Quote
Old 09-22-2004   #8
buzzyourtowers's Avatar
Is there a way to get a better OFF THE LINE launch?? I am 6'1" about 200lbs on my new x7 and woud like to know if in fact i even need a good off the line speed for racing or is it just a momentum thing. I have a V-stack, air filter, and a "boost" bottle. Thanks
buzzyourtowers is offline   Reply With Quote
Old 09-22-2004   #9
How fast does your X7 go
SpeedDemon101 is offline   Reply With Quote
Old 09-22-2004   #10
vtecds1's Avatar
I`ve heard of some people going up to 45mph.I`ve talked to Kirk at proline and said he knows of someone that went 40 and 45 out the box.Must be lucky...Just like the cags,if you get lucky enough,you get the cag with the big bore already in it.Factory Freaks!!!
vtecds1 is offline   Reply With Quote
Old 09-22-2004   #11
Syner's Avatar
I would suggest to get a tuned pipe first, then a walbro carb for better throttle response off the line (and corners). If you are running on a track maybe a bigger sprocket. Oh yeah, a big kick off the line will help too .
Syner is offline   Reply With Quote
Old 09-23-2004   #12
Well i took it out toight at adams kart track and it was maxed out on the stock speedo that reads up to 30mph and anything past that is a mystery to me untill i get a new speedo or sumthin. But hey thanks for the tips i wil be looking into the carb and exhuast ideas.
Old 10-10-2004   #13
same here, i was running around and buried the speedo at 30, all at stock. its pretty sick. I've got to do some tuning though. I feel i can get more out of this bike at stock. looking at a pipe to be the first thing to drop on. filter and a spark plug.
boasist is offline   Reply With Quote
Old 10-10-2004   #14
KOS
KOS's Avatar
I am not sure on my top end yet, but last night I noticed that there was a regulator screw for my throttle that I needed to take out. I wasnt getting WOP with the way it was set. Now it is much faster. I am not sure if it is faster than my hf cag though but I will get that tested soon. Although I do have an opportunity to put in a 60cc dirt bike engine that I may swap into it just havent decided if I want to put that much money into it? ALl in all it is a real nice bike though and has much more power than I thought it would have for a midi size bike. That and it looks bad a$$. with the R1 stickers on it it sure looks sweet!
KOS is offline   Reply With Quote
Old 10-10-2004   #15
Club PBP Member
B G Motorsports's Avatar
My speedo reads 60 mph and it will go 42 on the speedo stock.How accurate are the stock speedos?weve run against a HF cag and it just pulls me up top.Bottom sucks but it tops out good.By the way the HF has run against a moped and it said it was doing 40+mph.
B G Motorsports is offline   Reply With Quote
Old 10-11-2004   #16
genesisautoworks's Avatar
Thumbs up the stock speedos are a joke
This is a great bike but,
the speedos are A joke...Just like the so called CVT in these bikes...the gear ratio in the gear box that alot of people think is a cvt is not bad though. the truth is that these bikes out the box( after removing the governer, yes aka speed limiter...factory installed if you have an aarvi manufactured bike ) is 25 to 30 mph. If you tune the carb right and break the motor in like you are supposed to then look forward to 30 mph. I need to get my digital cam working or buy a new one... I will take a pick of one of the shops project bikes reading 30 maxed out on the speedo with the gear box disengaged, the bike standing still. the reading comes from the motor not the rear wheel or gear box...
Sacramento!!! Elk Grove!!!
Check us out at the up coming Test n Tune event @ Genesis Autoworks, inc
BBQ
Parking Lot
Free tech help
and other PB enthusiasts
call the shop for details, 916.685.0062 talk to sid!
genesisautoworks is offline   Reply With Quote
Old 10-14-2004   #17
gelwalk's Avatar
Talking
MINE IS STOCK WITH DIGITAL SPEEDOMETER RUNS 32.1MPH, IM 180LBS,
13 INCH TIRE X 25.4=330.2 X 3.1416=(1037 SPEEDOMETER INPUT)
gelwalk is offline   Reply With Quote
Old 10-15-2004   #18
My X7 does 33mph (tested with a GPS unit) on free mods- no air cleaner no throttle govenor, and tuned the stock carb a little- test done on level street, about 75deg. out, no wind, 175lb rider with a Garmin Streetpilot GPS. I would say impressive for this cheap thing!
PocketR6 is offline   Reply With Quote
Old 10-15-2004   #19
ok lets say out of the box i weigh 105 (truthfully) how fast will it go ? and how do you do the carb tning for an x-1 that i have?
yobe is offline   Reply With Quote
Old 10-16-2004   #20
spham's Avatar
I measure the tire circumference and it came out to 40" = 1016mm.
Did you measure your wheels or you got the measurement from somewhere?
spham is offline   Reply With Quote
Top Speed & Mods to get there sesshoumaru562 2Stroke Midbikes 332 07-26-2009 11:33 AM
Top speed cabridge Air Cooled Pocketbikes 51 05-05-2008 09:46 AM
top speed bogging gurt Air Cooled Pocketbikes 17 04-22-2006 11:51 PM
X7 Speed fmodesna8 2Stroke Midbikes 24 08-11-2005 10:53 AM
Page generated in 0.36147 seconds with 78 queries
