Originally Posted by standardracer So are you using a polini or bzm cases??? Got any pics ?? that will help a bunch . the polini cases dont use any type of case cooling like the BZM or blata . cylinder and head injected cooling only on the polini based motors . I have a polini bottom end with a BZM top end . Show us what you have and we can help you a little better |
Its not a Pocketbike cases. It will be mounted on a 5 speed engine.
I have found the information i need.
Ill use electric water pump.
Thanks very mutch for the info
