Post pics of your Blata...
Show Pictures Of Your Bike/s
heres my baby
Polini Gp3 13hp
GRC RX or GRC RR
VIDEO: GRC RX, 64.4mph run.
Free Blata 2.5
Polini vs Blata
RR 50cc 15HP en-route
Old 08-17-2008
BlackDM's Avatar
Do I need new Clutch shoes?
One of the clutch shoe clip/washer came off and kind of scratched up the shoe pads. From attached pictures. Do you think I need a new clutch shoes? Is it a good idea to just sand it down and use it again? What do you think is the best thing to do? What would you recommend?
Old 08-17-2008
2bamp's Avatar
Moderator
Re: Do I need new Clutch shoes?
If that was my bike, I wouldn't worry about those shoes. I don't see anything to be gained from sanding them. The gouges will disappear with a bit of wear. Good pics, BTW.
What I would be more concerned with is how the clutch drum looks. If that isn't perfectly smooth, it will wear your shoes very quickly. If a clip got caught between the shoe and the drum, it could have damaged it.
I have had limited success resurfacing a clutch bell. I took an M8 bolt of the same thread as the pinion, and fed it through the inside until snug. Then I stuck the end of the bolt into a drill. I used some sandpaper to restore the finish of the drum. Keep in mind that you can only go so far; past 80.5mm and I throw away my clutch drums.
Old 08-17-2008
BlackDM's Avatar
Thanks for the help. I really appreciated. When I open the clutch housing there is no clip inside. I only see the washer. I think the washer got caught between the shoes and the drum that's why the shoes are kind of scratched up. I think I am lucky. The clutch drum is till very smooth when touch. See pics.
I have another question. I am having a hard time trying to push the clutch shoe back down. You could see from the pics i posted earlier. Do I need a special tool?
Old 08-17-2008
2bamp's Avatar
Moderator
You will have to remove the spring to slide the shoe back on. To do this, you will need a set of digital measuring calipers. Measure the spring length, remove the spring by loosening the allan-headed setscrew, then fix the clutch. Clutch setup is absolutely critical; you have to be precise to .05 of a millimeter so that all 3 shoes engage at the same time.
Old 08-17-2008
standardracer's Avatar
I myself would run it the bell doenst look bad and if you say its smooth to the touch as long as it doesnt ahve any deep scratchs or grooves it should be ok and the clutch is ok IMHO too
Old 08-17-2008
StrayDawg63's Avatar
Just to play it safe I would take the clutch off just to make sure the clip isn't hiding in there somewhere.
Old 08-17-2008
BlackDM's Avatar
Thanks for the advice. Which way should I turn to lose the nut that hold the clutch. Is it counterclockwise to lose the nut?
Old 08-18-2008
Righty tighty, lefty loosey =]
  #9
Old 08-18-2008
2bamp's Avatar
Moderator
Counterclockwise. You will likely need to use a puller. Definitely DO NOT pry it off, or you will throw the crank off center and cause big time problems.
  #10
Old 08-20-2008
BlackDM's Avatar
I have a 5-ton 3-Jaw puller. I think I will use that. Thanks.
  #11
Old 08-20-2008
you need a small harmonic balancer puller with some long metric bolts to get that off with it will save you a headache over trying to use your 3 jaw . iot will also work onthe flywheel
  #12
Old 08-20-2008
Hexlobular's Avatar
Ooh! Good Idea! I was about to get a 3-jaw puller, but the harmonic balancer puller does make more sense. Thanks SRacer!!
Page generated in 0.34752 seconds with 49 queries
