Post pics of your Blata...
Show Pictures Of Your Bike/s
VIDEO: GRC RX, 64.4mph run.
GRC RX or GRC RR
heres my baby
Polini vs Blata
Polini Gp3 13hp
Free Blata 2.5
Horsepower blata elite 14 wrs
Old 01-10-2005   #1
JLsilver02's Avatar
Need new top end which way do I go??
Well guys I popped my top end on Sunday I hope to just get away with a piston and ring set. If I have to replace my entire top end I was thinking I may as well upgrade.
I have a GPracing Midi with a 5 port 50cc Polini. 17.5pbhn carb What would be the best top end to put on this engine?
JLsilver02 is offline   Reply With Quote
Old 01-10-2005   #2
daniel's Avatar
same top end as before
daniel is offline   Reply With Quote
Old 01-11-2005   #3
JLsilver02's Avatar
I order a stock set up from midsouthmini
does anyone bore these motor who can give me an idea what it would cost my jug might be worth saveing for a spare.
Old 01-11-2005   #4
DemonSpit's Avatar
Depending on how severe the damage is, sometimes, I say again, sometimes you can salvage it by starting with some 300 cloth backed sandpaper and sanding out the larger of the scratches and scores and them go to 800 and then 1000 to finish it off, I have saved a few cylinders this way, and used them as spares.
If the damage is really bad, with really deep scores, the cylinder would need to be sent out to be repaired, there are very few places that do this, since the cylinder needs to be re-nikasiled after the repairs. The places I have tracked down range anywhere from $125-$250 to repair and replate.
DemonSpit is offline   Reply With Quote
Old 01-11-2005   #5
JLsilver02's Avatar
thanks for the info looks like it is cheaper to replace it if the damage is too much.
Old 01-12-2005   #6
JLsilver02's Avatar
parts will be here tomorrow anyone have any assembly tips? It's been a long time since I rebuilt an engine.
Thanks, JL
Old 01-13-2005   #7
Assassin's Avatar
dont bother trying to fix your old cylinder... did you get the gasket kit w/ your new one?... when I take out my engine(RR) I take off the faring and tank/seat pannels.. loosten the water ports on the jug w/ a pan underneath, take out the lower radiator bolts and push forward, loosten the pipe mounting bolt up top, take the air filter off and carb off but just zip tie to the side, take off the coil wire, unbolt the engine mounts, move engine back and to the side to get the chain off, grab the engine w/ right hand and lift the front of the bike w/ left hand and gently remove out the bottom, this takes about 15-20min. if your not rushing, I havent had to remove the engine in the GP "knocking on wood" yet so I'm not sure if its the same.... should be something similar...
Assassin is offline   Reply With Quote
Old 01-13-2005   #8
blah's Avatar
Thanks, JL
Just make sure it's all clean and assemble it with plenty of your run-in oil, it will smoke for a bit but hey, so what.
Old 01-13-2005   #9
JLsilver02's Avatar
what type of oil do you recomend?
Old 01-13-2005   #10
blah's Avatar
I'm sorry, this is one of those questions that usually starts a b|tch fight, i'd rather just say use a good one and remember your brass ones arn't measured by your fuel/oil ratio so don't get carried away.
Old 01-13-2005   #11
elo
What's an elo?
elo's Avatar
elo is offline   Reply With Quote
Old 01-14-2005   #12
JLsilver02's Avatar
Exclamation Pictures
there will be more when I put the bike back together
Old 01-14-2005   #13
JLsilver02's Avatar
here are a few more tear down pics
Old 01-14-2005   #14
rdt
rdt's Avatar
Wink
Clean the bottom half of the motor before you put it together again...Doug......
rdt is offline   Reply With Quote
Old 01-17-2005   #15
JLsilver02's Avatar
All is well in GRC land the rebuild was a success. The bike ran strong yesterday. (thanks to MidSouthminmoto for stocking the parts I needed for the 50cc Polini)
Top pipe shootout Outlaw50 2Stroke Midbikes 48 02-08-2006 05:21 PM
Best Gearing For Top End Is? Best Gearing For Low End Is? pbmod Air Cooled Pocketbikes 5 05-22-2005 07:48 AM
Top end for 2.5 owners! xedup European Pocketbikes 1 01-22-2005 05:20 AM
sprocket change for higher top end? tnk7313 Air Cooled Pocketbikes 7 09-22-2004 07:28 PM
Top end problem Spud Warrior Air Cooled Pocketbikes 14 09-12-2004 11:57 AM
Page generated in 0.32460 seconds with 61 queries
