Mini Motard Pocketbikes
My new Mini Quad
who has what?
125cc pit bike
PBU Pockect Quad?
My minimoto
more Top speed
Old 11-28-2005
all motor cag racer's Avatar
Re: 125cc pit bike
graphics..mkae your own..use markers and crayons..LOL jp
i heard that sava made some motard tires.. i think they are for 10" rims tho.
dont know the exact measurements but check em out any wayz
  #22
Old 11-28-2005
Eight_Ball's Avatar
Re: 125cc pit bike
Got my decal kit for 55€ from a local online mx dealer, more or less your $60-70... CoulndŽt find anything nice cheaper.. But i think theyŽre worth the mo, its a really nice whole DC shoes kit. They are thick quality stickers. IŽll try to take some pics
Originally Posted by snowboardgeek1
I'm trying to find some nice graphics for my bike, but the good ones go for at least 60-70 bucks on ebay. Know of any cheap
graphics/decal kits?
my bike came too with 12 and 14" wheels, i prefer them over 10" wheels.
Same **** happened with my front brake, i was doing the setup at job and a "funny" coworker pressed the lever You can take it out of the bike and take apart the two shoes, then open brakeŽs piston with a screwdriver. I changed brakeŽs oil and bleeded it too, but it isnŽt needed.
youŽll love how the bike rides, believe me
I haven't had time to post up pics of my bike, but I will soon. To my surprise, the bike came with 14" wheels up front, and 12" wheels in the rear. Sits pretty high, which is cool with me. I messed up putting on the front wheel so now I have to bleed the front brake system (don't ask me why I have to do it...I feel stupid enough as it is haha). Have any of you guys had to bleed your front brakes?
Overall the bike looks good, but its chinese quality so its not GREAT. I'll see how it rides hopefully sometime this week.
  #23
Old 11-28-2005
snowboardgeek1's Avatar
Re: 125cc pit bike
So you're saying its not needed, to bleed the brakes? All the fluid is gone from my brakes since I took the whole front brake assembly out. Well, I'll try to bleed the brakes anyhow. Any tips?
  #24
Old 11-29-2005
Eight_Ball's Avatar
Re: 125cc pit bike
If your fluid is gone youŽll have to bleed. First of all you need one thing like this:
http://www.pocketbikeplanet.com/gall...0&ppuser=15146
You want the bigger syringe you can find. They are used to feed new born pets. You need some tube, the same size used to feed cagŽs carbs will be fine. YouŽll need an empty cup or something to bleed the fluid to. YouŽll need a small wrench to open/close the bleeding screw. YouŽll need some duct tape or a friend to help you. YouŽll need DOT4 brake fluid, any brand (be careful with brake fluid as it eats it all)
Here we go, fit the tube to the bleeding screw. Open the reservoir and take out the rubber seal. Fill the syringe with fluid and fit it to the tube you previously fitted to the bleeding screw. Press the syringe to fill the system with brand new fluid, be careful and do it slowly, checking reservoirŽs level. Using a syringe and forcing the fluid through systems lower part will help to keep as less air bubbles as possible, less air youŽll have to bleed later .
Once you have filled the system close the bleeding screw. Now its time to bleed the brake.
To bleed the brake you take out the syringe from the tube and leave the tube attached to the closed bleeding screw. Pump the lever with your hand till you feel some pressure, use the duct tape to keep the lever pressed. Open the bleeding screw, youŽll see that some fluid drains and youŽll see some air bubbles too. When the bubbles stream stops, close the bleeding screw. Cut the duct tape and pump the lever again till you feel some pressure, leave it pressed using duct tape and repeat the bleeding routine till you see that no air bubbles come from the screw. From time to time check reservoirŽs level, as youŽll have to fill it.
Once you have bleeded all the air, fill the reservoir to its marked level, place the rubber seal and close the cap. Pump the lever again, when you can feel the pressure duct tape the lever and leave it that way overnight. YouŽre done
  #25
Old 11-29-2005
Re: 125cc pit bike
Hey thanks bro. I appreciate the writeup. I'll try to get Robert to add a how-to section for this forum, and post up your writeup on how to bleed brakes. Thanks again.
  #26
Old 11-30-2005
Eight_Ball's Avatar
Re: 125cc pit bike
Here is a low-res pic of my bike with the new stickers and taller seat
  #27
Old 12-07-2005
Re: 125cc pit bike
is this a good pit bike. it looks sweat
http://westcoast-products.com/scoote.../DB125BLK-19M/
  #28
Old 07-21-2006
Re: 125cc pit bike
So on the Stock China Forks. R they Rebuildable ? I heard that they didnt have any fluid in them. If u can Put fluid in them then i need to get to Work. does any one Know? or has anyone rebuild the front forks? (forks like the ones in the picture of the link above)
  #29
Old 07-22-2006
Re: 125cc pit bike
try surfing that question over at planetminis.com they are tons of threads relating to this question.
  #30
Old 11-24-2008
mx3rider's Avatar
Re: 125cc pit bike
Originally Posted by snowboardgeek1 View Post
Thanks for the tips. I'll definitely check these things out. What oil, gas, brake fluid, etc do you guys use? I feel like such a newbie haha.
i use motul 4-stroke sae 10 w 40 motor oil
91 octane chevron
i havent changed my brake fluid yet...
any tutorials someone can pm me on how to change brake fluid?
1 big thing to look at that i shouldve looked at before is the rake on the rear and from suspension your front forks should not be near straight up..or you will have non-existant shock absorbtion... i can back this up with the fact that i went down to apex near vegas(where i live) and hit a small cantelope-sized rock in the top of 3rd gear and i ate it and thought i broke my ankle! if you do not have any rake in your front forks then consider cutting and welding the body near the forks to give you rake
ride safe
  #31
Old 11-24-2008
mx3rider's Avatar
Re: 125cc pit bike
I'm trying to find some nice graphics for my bike, but the good ones go for at least 60-70 bucks on ebay. Know of any cheap graphics/decal kits?
check ssr motor sports . com as they are really cheap to buy
(leave out spaces)
or spray paint them as i did to mine
  #32
Old 11-24-2008
SpyGuy's Avatar
Re: 125cc pit bike
Hey, MX3, you do know this thread was over two years old, right ...........................?
Good tips, though ...
  #33
Old 11-24-2008
mx3rider's Avatar
Re: 125cc pit bike
...oh crap
haha
  #34
Old 11-24-2008
SpyGuy's Avatar
Re: 125cc pit bike
*laffs* Don't feel bad - I've done that too .. Sometimes the "New Posts" button pulls up stuff from three-four weeks ago or longer.
Does the BT-Hydra AC from Badazz have suspension? Help finding new bike. Adam Connell Air Cooled Pocketbikes 7 04-28-2005 12:37 AM
Newbies, Read If You Want To Know What Is The Good Stuff.... Day-Tone-A MX Air Cooled Pocketbikes 38 04-12-2005 01:48 PM
Best W/C 49cc Racing Bike For $1400 Or Less. pbnut Water Cooled Pocketbikes 13 02-18-2005 06:08 PM
Page generated in 0.60397 seconds with 58 queries
