| cobra s4 crankshaft and mods ? I just ordered a cobra S4 from MPR before finding this forum . Before it gets here though I already have some modifications in mind . The first ? i need answered is does this quad have a 10mm or 12mm pin. I need to order the correct crank. I'm going to order through HKMOTOS and it takes a couple weeks from what i understand to get here so i want to order now as i just ordered th quad today .
As far as mods go i was going to order the yellow jacket head kit and with full circle crank , dellorto style 15mm carb , 78 tooth #25 chain rear , 3rd bearing 6 tooth clutch housing , chain x2 for length ,and the 2 shoe red spring clutch , along with the metal pull start with alloy cog and the lightned flywheel Ps also the triple stage reed.
This is my 1st 2 stroke build ever , did i miss anything ? and does this combo sound good ?
Also going to get the chain breaker
Thanks in advance for you input |
