Im 205 and it does ok with me on it out in the gravel but as far as in the grass it would need geared down because it slips the clutch too much in the rough . but I can tell you it will run between 25-27 mph with me on it once it gets going. I think it needs geared down and a banshee clutch .
the frame is pretty well constructed the front suspension sucks as it travels about 1/2" due to the shotty shock on the front the rear shock is plentiful with travel unless your overweight like me :P .
