Originally Posted by Kurlon I'll just toss this in, most motors put down MORE power across a wider power band WITH a properly setup exhaust than none at all. Pipes, even 'straight through' units do indeed supply back pressure, and more importantly can supply a scavenging effect (Hence the expansion chamber) that can actually pull exhaust out and fresh mix in FASTER than the motor can sans pipe. That means MORE power. |
doh
why do people hink you can go faster w/o the muffler?
on a dragster this it true and on 4 stokes it is ok
2 stroke mo way it needs the pipe to work corectly
dont say something unless you know it
