sit in the back the most possible. go at about... 4mph and then give a swing back on the sterring while opening the throttle
and then it's just about givin some gas to lean it back and when you feel that the bike will fall press the rear brake and then the gas and the break....the thing is to get the balance !!!
this is what i do for wheelies.... if someone have another easier trick...let me know!!
be careful cause you might break your bike's fairing!!
by the way for doin whellies you need more torque at low rpm
