No worries. Sorry, no more pics at this stage. I haven't touched it for months, been busy with other projects, though I did strip it the other day and go over some of the welds around the headstem and I beefed up the welds for the shock mounts because I'm probably going to ditch the shock and go rigid due to the chain adjustment varying wildly depending on the amount the shock (which is a bit of a joke BTW) is compressed. I also painted the frame and swingarm satin black, it looks pretty nice
For sure you should definietly match the velocity stack to the carby. Actually what I did was bore the carby and black plastic manifold out, ground a big bellmouth on the carby and bored the veloctiy stack to match. There is a detailed article on this site under Chinese Pocketbike FAQ or something like that, it tells you all you need to know. For the exhaust, the port is ok as is (can be improved, but I don't know if I'd bother) but look up the CAG exhaust modification on this site for how to chop bits out of a stock cag exhaust (like the one I patched onto my bike) as those are better than the exhaust my bike came with originally.
For a tacho I dunno, the only options I've seen were too dear so I never bothered. Speedo is easy and I added one to my bike, just get the cheapest bicycle speedo you can find, program it up for the wheel diameter and stick a magnet on the disc rotor. I got my bike up to 50kph, for real 50kph as the bicycle speedo is 100 times more accurate than those dodgey Chinese pocketbike speedos.
Since it's a magneto ignition there's not really anywhere to tap in for lighting, and anyway, direct lighting sucks bad. Every time you idle the lights dissapear. If you really want lights, I'd go a cheap battery operated bicycle halogen headlight.
For tyres you might be screwed, I dunno. The knobby ones that came with my bike say 12" on the sidewall but they're wrong! I bought some 90/65-8" grooved tyres that fit perfect. I don't know what other mini dirt bikes take 8" tyres, you might have to ask your bike shop.
Funnily enough after reading the Chinese air cooled
pocketbikes FAQ on this site I did the same as that's what they advise, but there was nothing in my tank and all the bolts were ok too. I didn't bother loctiting them and none have fallen out though my exhaust bolts came loose a few times due to crappy spring washers. The main thing was the needle position was set too high so it ran rich. I dropped it a notch or two and it was sweet.
