47cc converted to 110cc
Pocket ATVs are on the way
Cobra S4 questions....
pics of your quads
49cc A4 Quatro Quad
LOOK AT THIS!!! gotta get it
save the clutch
New quad --> Cobra S4
Old 03-20-2008   #21
Crazyj15692's Avatar
Re: 47cc converted to 110cc
Yeah. that's why it would be great. lol be a nice drag bike if you added some stronger parts.
Old 03-21-2008   #22
Haha, 160cc! Are you kidding me?! Do you know how hard it is to even fit a 110cc engine? It's HARD!
Old 03-21-2008   #23
Well a 160 is still posssible.
Old 03-21-2008   #24
I allready have the 110cc engine! i don't want to go out and buy a new engine
Old 03-23-2008   #25
I know what you mean man. I didn't know if you had tons of cash to spend or something.
Old 03-23-2008   #26
No! This is a very very low budget project! So everyone who has an engine, angle grinder and a welding machine should be able to do this
Old 03-23-2008   #27
nofearX18's Avatar
lookin good so far. cant wait to see more.
nofearX18 is offline   Reply With Quote
Old 03-24-2008   #28
Thank you very much man It's nice to see people showing an interest in this project!
Old 03-26-2008   #29
S0UTHERNCALINATE's Avatar
Originally Posted by Esser View Post
Hi again.
Today i cut 10 cm of the frame again, because i started out extending it by 25 cm, wich is too much. Extended 15 cm, the engine will fit PERFECT! It looks like it was made to be there. I also cut of the old engine mount, and made a new one There is still a LONG way to go, and a lot ot problems ahead
1: I need to get the exhaust to fit, but i don't have it yet.
2: I need a new sprocket for the rear.
3: Need a new chain.
4: Need to mount the engine so the chain will fit.
5: Need to find out where the gastank can be mounted.
6: Probably A LOT more!
There will be some more pictures soon.
i added the same motor your adding in an ATC 70
funner than ****..
anyways i have an extra exhaust, im running an
FMF Power Core 4
but i have the stock pipe for the 110 (4 stroke dirbike exhaust) if you need it
ill let it go pretty cheap PM me an offer if interested
S0UTHERNCALINATE is offline   Reply With Quote
Old 03-26-2008   #30
funner than ****..
FMF Power Core 4
I'm so happy to hear that it's fun!!! I CAN'T WAIT untill it's done!! But i don't need an exhaust, i have on, the guy i bought the motor from just needs to ship it to me But thank you for the offer!
Ps. I live in Denmark, so it would be pretty expensive in shipping cost to buy your exhaust!
Old 03-26-2008   #31
haha good point, i gut lucky!
my atc-70 is much larger than your miniquad,
well a little, about the size your making it..
so i needed no modifications, if mounts like a regular 50cc honda engine, i was stoked! did need to purchase a new chain and sprocket though haha and too bad! cali to denmark haha ouch shipping prices would gouge you, unless you used a flat rate international shipping tube, but i doubt the exhaust would fit! haha it was worth a try! hopefully the one you have will work, and not just kill the engine (my friends bike sounds like a can of nuts and bolts ) and mine runs fine all i did was buy the FMF power core 4, 60 bucks on ebay, highly reccommended
Old 03-26-2008   #32
also one last thing, add a few more frame supports, ive heard of people riding for 2 days on modded 110 pocket bikes then BAM the power of the engine snaps the frame...
would hate to hear another war story, with a really cool idea like this
good luck!
Old 03-26-2008   #33
I'm having pretty big trouble finding a sprocket that fits the new chain! Because it also needs to fit the old axel... It needs to have a hole in the middle that is 2,5 cm in diameter, and it needs to be big enough for a larger chain. How do i find one like that...?
Old 03-26-2008   #34
nofearX18's Avatar
Contact somewhere that makes the sprockets.... im not sure who but if you give them dimension they may be able to custom make you one.
im guessing your chain is 420 correct?
Old 03-26-2008   #35
I actually don't know... Because i don't have the chain yet But i think it is 420 It's has to be the same size as the 110cc dirtbikes and Choppers have
Old 03-26-2008   #36
nofearX18's Avatar
well you can run either a 420 or 428 depending on what sprockets you buy...
if you are leaving the stock sprocket on the engine then you need a 420 sized chain.
Old 03-26-2008   #37
I leave the stock sprocket for the engine So thank you VERY much! Just needs a new one for the back... I was just thinking something. What if you cut every second tooth of the standart mini atv sprocket? would the chain fit then?
Old 03-26-2008   #38
nofearX18's Avatar
lol ummm you can try.... not sure how that will turn out...
Old 04-11-2008   #39
I just got the exhaust today So i will be working on it again soon!
Old 04-13-2008   #40
125ccCRazy's Avatar
to make the tank clear the carb, what about taking the top two bars and running them straight down to the seat area instead of angling down and then back, this would raise the tank a few inches by the way it looks...
Get some measurements on the bolt pattern for your sprocket and pm me, I'll cheack what I have, maybe one off of a 4 stroke pocket bike will fit... I'll need to know how many bolt holes and the distance between them...
Page generated in 0.35734 seconds with 77 queries
