47cc converted to 110cc
Pocket ATVs are on the way
Cobra S4 questions....
pics of your quads
49cc A4 Quatro Quad
LOOK AT THIS!!! gotta get it
save the clutch
New quad --> Cobra S4
Old 03-16-2008   #1
Hi everybody. I'm working on converting a 47cc mini ATV to have a 110cc 4 stroke engine from a china dirtbike.
I have extended the frame, because it wouldn't fit if i didn't. But there is still a lot of work to go. I will keep updating this thread until i'm finally done.
The new engine is a 110cc 4 stroke 4 speed, from some china dirtbike thing.
This is how it used to look.
http://img255.imageshack.us/img255/3990/atvod5.jpg
Here is it stripped from everything.
http://img179.imageshack.us/img179/7544/newatv3nw5.jpg
Cut i half.
http://img255.imageshack.us/img255/3933/newatv1yx0.jpg
And extended
http://img181.imageshack.us/img181/7631/newatv2df5.jpg
Old 03-16-2008   #2
Council Member
sr20hardbody's Avatar
Re: 47cc converted to 110cc
nice work! you need to make a step by step how to on this because im pretty sure alot of people with these pocketquads will want to do the swap since they have major clutch issues.
Old 03-16-2008   #3
Thank you very much! I hope this thread will help out some people I will be updating it as much as i can
Old 03-17-2008   #4
bananas7's Avatar
wow dude, i gues you will "born" a freaky awesome and even fast ATV. Nice work so far.... keep converting
bananas7 is offline   Reply With Quote
Old 03-17-2008   #5
haha, thank you very much I got some steel plates to day So i will be making the engine mounts soon
Old 03-17-2008   #6
nofearX18's Avatar
Now this is cool!
Keep it up. cant wait to see more.
nofearX18 is offline   Reply With Quote
Old 03-17-2008   #7
Originally Posted by nofearX18 View Post
Now this is cool!
Old 03-19-2008   #8
Hi again.
Today i cut 10 cm of the frame again, because i started out extending it by 25 cm, wich is too much. Extended 15 cm, the engine will fit PERFECT! It looks like it was made to be there. I also cut of the old engine mount, and made a new one There is still a LONG way to go, and a lot ot problems ahead
1: I need to get the exhaust to fit, but i don't have it yet.
2: I need a new sprocket for the rear.
3: Need a new chain.
4: Need to mount the engine so the chain will fit.
5: Need to find out where the gastank can be mounted.
6: Probably A LOT more!
There will be some more pictures soon.
Old 03-19-2008   #9
Council Member
hey esser! i found this at pbu and thought it might help you figure out how things go even though your set up is one of a kind. another thing you might wanna call pbu and tell them to send you 360 pics of that 4 stroke mini quad cuz you wanna buy one just to see how they did it then compare yours. heres the link
http://www.pocketbikesunlimited.com/...-mini-quad.jpg
Old 03-19-2008   #10
Crazyj15692's Avatar
Nice. I can't wait to see how this turns out. are you painting the frame???
Old 03-19-2008   #11
nofearX18's Avatar
This is sounding pretty cool.
Any plans as far as making some sort of body for it or painting the frame?
Can you get some pics of your progress. this thing is going to be a pretty sick bike.
Are you going for a lot of low end power or do you want top speed? with the tiny tires on that thing gearing is going to be hard to determine. id say go with the highest gearing you can... id do a 17:28.
anyway cant wait to see more...
Old 03-19-2008   #12
Thank you guys But i have a pretty big issue... I don't know where the hell to mount the fuel tank. The carburator sticks up, where the gas tank use to be, and the gastank has to be mounted higher then the carburator. Maybe on the handlebars? But that would just look so stupid!
I also don't know where to find a rear sprocket for the back that fits... The old one is too small for the new chain, wich is a bigger one. Maybe someone can help with that?
As far as the body go, i think i'm going to cut it, to get some of it to fit
Old 03-19-2008   #13
Putting the fuel tank on the handlebars wouldn't look to bad. it would look like a water cooled bike but with gas in where the water is supposed to be.
Old 03-19-2008   #14
It will look pretty stupid The fuel tank is pretty big compared to that little bike, and it has a weird shape... But i may have to do it.
Old 03-19-2008   #15
Council Member
hey look at that link i showed you they have the gas line routed against gravity and im sure it works especially once you start the engine. and you might wanna look for a new manifold since theres quite a few to choose from on ebay or turn it around if possible to make the carb point in a different direction.
Old 03-20-2008   #16
My carb sticks out more then the one on the picture... But i did save the picture! There may be some usefull stuff on there
Old 03-20-2008   #17
Hi again. Here is a new picture I have shortended it, removede the old engine mount, made a new engine mount and fixed the holes where the old engine mount was. Still a LONG way to go, but it's getting closer
http://img245.imageshack.us/img245/3751/newatv4nx3.jpg
Old 03-20-2008   #18
Looks nice. Have you thought about putting an even bigger engine on. like a 160 or 150.
Old 03-20-2008   #19
dragonkeep2000's Avatar
get the carb mount that lets you redirect the carb 45degrees so it sticks out the side of the bike instead of facing rearward....if you have a problem in finding it just get the intake mount instead that lets you use any of the intakes..i think they call it a 12 position intake mount....
Old 03-20-2008   #20
Council Member
i think the 150-160 will tear that frame to shreads! the 110cc will be way more then enough the 160 with a high compression piston in that quad would prolly do a back flip at launch!
Page generated in 0.32823 seconds with 77 queries
