47cc converted to 110cc
Pocket ATVs are on the way
Cobra S4 questions....
pics of your quads
49cc A4 Quatro Quad
LOOK AT THIS!!! gotta get it
save the clutch
New quad --> Cobra S4
Old 12-21-2005   #1
49cc A4 Quatro Quad
I am new to the pocket bike scene. I recently orderd two mini quads from rabbitscooters.com. I am having problems with both of them with no help from the them as of yet. I have experience with mechanicl issues but because these things are so simple, sometimes thay can be the most difficult to work on.
1st one:
Can start, runs rough but dies when I take choke off and apply throttle. I can only see one screw on carb for adjustment.
Slight leak in exhaust manifold. I teghtened the screws up but it still leaks with oil spewing out. I am afraid to tighten any more and break screws.
2nd one:
Will not start. I have a bright blue spark and gas appears to be on plug. I'm thinking possible kill switch issue...
Has anyone dealt with these type of atv's before????
Thanks,
Griff
bgriff007 is offline   Reply With Quote
Old 12-21-2005   #2
Re: 49cc A4 Quatro Quad
By the way..here is a picture of one....
Old 12-21-2005   #3
pocketbikerider1's Avatar
on the first bike check if theres a good flow of gas to the carb and the second one may just take a while to start my frineds quad took him an entire day to start when he first got it
pocketbikerider1 is offline   Reply With Quote
Old 12-22-2005   #4
Thamks for replying..it's so dam in Chicago right now, it makes it hard to work on int he garage but I will verify.
Old 12-23-2005   #5
jdo008's Avatar
its the same engine from the "47cc" cag, if you want you can go over to the forum and find more info on the enigne
jdo008 is offline   Reply With Quote
Old 12-23-2005   #6
Checked out the cag forum..lots o good onfo thanks.
I also did a search for "needle adjustment' and found a huge amount of info...I have only two adjustments, the idle adjustmetn screw on the outside of the carb (left side when sitting on bike) and the needle adjustment inside the carb. Going to check the needle posision tonite and play with the idle as well.
Thanks to all who contribute to that. These things are more complicated than they appear!!!!!!!
Old 12-23-2005   #7
when you mess with the needle inside when your are changing where the c-clip is be careful they shoot away easily and you will lose it happened to me n underground a few times, really frustrating
Old 12-27-2005   #8
Smile Re: 49cc A4 Quatro Quad
Thansk for the info..
One big problem I resolved with help from the "Things to do with new bike" listing: clean out the gas tank. It had a huge amount of plastic shavings in it and the fuel filter was clogged. Once I cleaned them out and messed with the idle adjustment, they run pretty good now. In fact they run better with each time I ride them.
Thanks again for all the help and replys.
Griff
Old 01-16-2006   #9
badazztoyz.com's Avatar
so far i know two factories making garbage pocket quads..do yours have black or gray frames..the black framed ones are junk..dont know if the other factory uses gray or black frame
Old 01-17-2006   #10
i have the black frame and mine is runnong great same with undergroundrida
Old 01-26-2006   #11
I have two that have grayish silver frames and bought them form rabbit scooters out of Cali. One runs like mad and the other is a little boggy and doesn't have the top speed the first one has. I need to adjust the needle (c clip) as it is spewing a large amount of oil out the exhaust.
Old 01-26-2006   #12
sweet..glad they are
Old 05-22-2006   #13
you can put off road tires on this right? i was thinking of putting the pbu knobby tires on it and was wondering if they would work.
andr3w is offline   Reply With Quote
Old 05-29-2006   #14
do pocket quads have the same engines as cags can u put cag parts on pocket quads
kevin6 is offline   Reply With Quote
Old 08-06-2009   #15
i have that same A-4 Quattro / Type R but my one when i rev the engine it turns of and some times it wont turn of and i have to run the the quad and it will go a bit slow so can someone pleas help me out
qwerty01 is offline   Reply With Quote
4 stroke Engine Talk.. 110cc, 49cc, 70cc? what do I have? Michael_K 4Stroke Midbikes 28 09-14-2005 12:26 AM
which is the best 49cc 4t??? u sucker just got served 4Stroke Midbikes 38 07-07-2005 04:48 PM
47cc vs 49cc Tapethejunkie Air Cooled Pocketbikes 3 06-13-2005 02:37 AM
OOps, 49cc is also a 72cc bartw 4Stroke Midbikes 13 03-13-2005 01:23 AM
49cc VS 47cc banzairx7 Air Cooled Pocketbikes 28 01-29-2005 09:14 PM
Page generated in 0.34884 seconds with 62 queries
