47cc converted to 110cc
Cobra S4 questions....
Pocket ATVs are on the way
pics of your quads
49cc A4 Quatro Quad
LOOK AT THIS!!! gotta get it
save the clutch
New quad --> Cobra S4
Old 01-06-2009   #21
Re: Cobra S4 questions....
thanks alot well check all that out!
hicks005 is offline   Reply With Quote
Old 10-11-2009   #22
Originally Posted by demonsparkx-*x7* View Post
yeah its gotta be a stuck cable pulling the barrel open in the carb causing it to accelerate on its own,or just like the other person said a broken clutch spring could also be causing this probelm if you dont have a local shop wich u can purchase replacment parts "if needed" i highly recommend partsforscooters.com im a constant customer of theres and they have pretty much anything that you may need.good luck
My cobra s4 also revs up and then stalls.
I have cleaned out the carb and replaced the old clutch springs.
if it is the cable how do you go about fixing it.
Mexico is offline   Reply With Quote
Old 10-27-2009   #23
reptile411's Avatar
My S4 from MPR is a big POS. If you hve problems with it bogging and dieing check the petcock. Turning it a few time 180 degrees. Mine dose the same thing and this normally fixes it, I have yet to tear it apart to perform a real repair on it. I am 140lbs and cant get but maybe 10mph on flat ground, Off road forget it, Mater of fact here is a video I took while out on the farm. In that video you can see WOT just doesn't go. Most of the time on terrain like that I have to push it along then jump on and go. If I slow down to much I have to kick it along just to keep going. A little friendly hint to, if you get/got one and plan on going in some mud make sure your pants cover your boots. Mine didn't and the front tires will kick up and fill your boots with mud. Oh yeh and as a disclaimer in the video I have no Helmet on, Dont ever ride without one. I will practice what I preach.
reptile411 is offline   Reply With Quote
Page generated in 0.78236 seconds with 23 queries
