Pocket ATVs are on the way
pics of your quads
47cc converted to 110cc
LOOK AT THIS!!! gotta get it
49cc A4 Quatro Quad
Cobra S4 questions....
New quad --> Cobra S4
Old 01-26-2008
Leaking Carberator
I have a Quattro A4.
At th bottom of the carberator their is a clear tube that usually has no gas comming out of it. Randomly there has now is gasoline rapidly leaking from it. I tried just pinching the tube at the end but it very notibly messed up the performance.. HELP
Old 01-27-2008
Minis&More 2's Avatar
Re: Leaking Carberator
You have dirt in your fuel system. Most likely it has caught itself in the fuel shut off valve inside the float bowl. Take off the carb to clean it properly. If you are not mechanically inclined, take it to a carb guy to have it tuned and cleaned. If you are, take the float bowl off, pull the pin out of the float spring and the valve will come out easily. Clean all parts thoroughly as though you are a heart doctor. Before you install it again, make sure your fuel system is completely clean, because from the factory, there is always some kind of dirt or something in the system. Put a nice, big, new fuel filter on it and fuel line, any parts store will have this.
Old 01-28-2008
I dont have the money to get carb guy to do it. I dont want to jack up the carb cause i dont 100% know what im doing so do u think u could post pictures on how to do it please. I need your help and im sure it will help others too
Old 01-28-2008
Take the bowl off and clean it also. Its easy to do. Just take your time.
Old 02-07-2008
I went ahead and just bought a new carb. after i totally screwed up the old one. But after istalling the new one my quad VIBRATES ALOT MORE. only when idle though?? Any Thoughts????
Old 02-08-2008
How did you screw up the old one?
How does it run rough at idle?
Old 02-08-2008
I just decided to replace it..
When it is idle it vibrates ALOT
Old 03-25-2008
wiifreak1993's Avatar
I could be 2 things:
1. Your idle speed is too high. Look for a gold screw on the side of your carb, and turn it clockwise to speed the idle, or counter-clockwise to slow down the idle.
2. Check over all of your bolts on your bike, they may not been put on properly. If it is still and issue, find where the bike (in your case quad) vibrates from, and install rubber washers to absorb the vibration.
I you still have trouble then look over the carb you bought and make sure its clean inside.
  #9
Old 05-22-2008
hey guys, i ran into the same problem as this guy with the leaking carb. the 3 inch tube that hangs out the carb(the "overflow valve" i think) is leaking fuel like crazy. i have to close the fuel line valve to keep it from leaking. i read what yall said on how it could be dirt in the carb, but how could that cause the carb to leak, its almost like the gas is just running straight though the carb and out that tube. I also tried plugging up the tube and all that does is cause the gas to leak out the airfilter. And i messed with the idle screw so i cant get it to start up, which im not really worried about right now i just want the leaking to stop, and also if there is a "number of turns out" the carb that the idle screw should be at. please get back to be on some info on how to repair this thing, im tired of this thing leaking gas all over my garage =/
  #10
Old 05-22-2008
cpparent's Avatar
ok guys these are verry simple carbs to fix the reasonwhy the overflow tube is leaking is because your flooat is stuck or peirced therefore it is not floting up to push those two little legs that push a plug pin and shuts off the fuel entry.....
step 1
take the bowl off the carb the jet, float,legs and pin are now exposed..
step 2
clean everything with carb cleaner
step 3
replace all components back the same way they were when you took them apart...
if your over flow is still leaking you might have to adjust the legs
repeat step 1
then bend the little legs down a little bit and repeat step 3
if your carb still leaks or you did not bend the little legs enough or the plug pin is deffective(the little spring loaded pin with rubber on the tip)
to verify if it is still good make some gas flow through the carb and the try lifting the legs softly if gas flow stop its fine if it does not the plug pin might be defective...... if you still need more help hit us up
cheers
  #11
Old 05-22-2008
omg i love you man, thanks for the help!!
  #12
Old 05-24-2008
cpparent's Avatar
that what we are here for have fun with your PB
  #13
Old 05-24-2008
Nice advice.Great job writing it and its good to know that the knowledge is spread about.Peace
  #14
Old 05-25-2008
easy as pie!, (you could just drain your gas from the tank when your done riding, i only put in half a liter of gas at a time because of the leaking bastard)
  #15
Old 06-24-2008
I have the quattro a4 too i have the same problem it always leaks everywhere but if u tilt the quad on its side it will leak all the gas in the carb and then u can even do this if u want my friend has the cobra s4 and i was doing that like mine but if u want take the gas hose od like where the black hse goes to the carb and drain all the gas out of the gas tankk and put the hose back on and then start your quad and let all the gas that is sitting in ur carb drain out like ride the quad with out gas in it cause u still have gas in the carb so ride it till the gas in the carb runs out then fill the tank with gas like half way of the tank and it will run good with out leaking it usually leaks when u ride it alot but try that it will help!!! [:
Page generated in 0.38417 seconds with 57 queries
