47cc converted to 110cc
Cobra S4 questions....
Pocket ATVs are on the way
pics of your quads
49cc A4 Quatro Quad
LOOK AT THIS!!! gotta get it
save the clutch
New quad --> Cobra S4
Old 02-20-2008   #1
Mudd Boggin'!!!
I just went this weekend after it rained really hard mudding my quattro a4 (pocket quad). It wasnt exactly mudd boggin but it was some pretty thick/deep wet stuff!
It was very fun and im sure it was terrible for my quad. Well anyways their was alot of water/puddles that i went through. Whenever i went through going very fast in a deep puddle the quad shut off. I was wondering if their is a certain part of the engine or something that cant be touched by water? And is there away to make it water resistant?
P.S. the quad started up after about 2 minutes of wating when it cut off, and i do recomend it if you have mud tires, suspension, ect. and dont are not worried about breaking your quad. And i never got stuck
irishfootball100 is offline   Reply With Quote
Old 02-20-2008   #2
Crazyj15692's Avatar
Re: Mudd Boggin'!!!
The water was going into your airfilter most likely and you should buy one of the airfilters that are water proof.
Old 02-23-2008   #3
Re: Mudd Boggin'!!!
Where? and is it possible to make a snorkel for it?
Old 02-23-2008   #4
Re: Mudd Boggin'!!!
Yeah you can make a snorkel for it. Just use the airfilter you have now and make a custom snorkel. That would look pretty bad ***.
Old 02-23-2008   #5
nofearX18's Avatar
Re: Mudd Boggin'!!!
hahaha cool.
now put it on some 33" ATV tires and soup it up pretty good. lol
nofearX18 is offline   Reply With Quote
Old 02-23-2008   #6
Re: Mudd Boggin'!!!
Yeah...I can't even imagine how that would look and how much speed it would lose. lol
Old 02-24-2008   #7
Re: Mudd Boggin'!!!
Two questions
Where can i buy a waterproof airfilter?
What would i make the snorkel out of? PVC pipe maybe?
Old 02-24-2008   #8
Re: Mudd Boggin'!!!
If you are going to make a snorkel you won't need a waterproof airfilter. You could make it out or pvc or metal...
Old 02-24-2008   #9
Re: Mudd Boggin'!!!
Here is a link for the waterproof airfilter http://www.davesmotors.com/store/product1910.html
Old 02-24-2008   #10
Re: Mudd Boggin'!!!
Thanks, im not a welder or anything so I think ill just do: pvc pipe, gorrilla glue ( or some other super strong water proof glue), and water proof duct tape. And at the end of the snorkel what do i put?? Like an air filter?
Any Suggestions?
Old 02-24-2008   #11
Re: Mudd Boggin'!!!
Yeah you could put an airfilter at the end or you could build the snorkel from the airfilter on the carb.
Old 02-24-2008   #12
Re: Mudd Boggin'!!!
Yea im gonna build it from my V-stack. So after its done will i be able to go in water? (like 1 foot or so?)
Old 02-24-2008   #13
Re: Mudd Boggin'!!!
I guess. it may be a little bad for your engine but I think it will work.
Old 02-24-2008   #14
Re: Mudd Boggin'!!!
yeah im gonna try not to just drive through pure water. Its because when i go go mudding their usually is water on the side and when i go through it going fast the fun is over. Ill try not to drive through water to much plast where the snorkel starts.
Old 02-24-2008   #15
Minis&More 2's Avatar
Re: Mudd Boggin'!!!
You also have to protect the wiring. If the kill switch gets water in it, its like shutting off the motor manually through the switch. If you are going to put a snorkel on it, try finding a prebent water hose from a car. The hoses are almost identicle in size with the air filter adapter, and if you seal it right, it should work great!!! Take the adapter into a local car parts store, or radiator shop, and match it up with a hose that they have in stock. Message me if it works well!!!
Minis&More 2 is offline   Reply With Quote
Old 02-25-2008   #16
Re: Mudd Boggin'!!!
2 questions- How do i protect the wiring?
Can u send me a link to the prevent water hose thingy just to know what im lookin for?
Old 03-01-2008   #17
Re: Mudd Boggin'!!!
At the end of the wires, where it's solderet, you have to cover it in electrical tape. That should work
Old 03-12-2008   #18
Re: Mudd Boggin'!!!
how do you go mud bogging i can barly go on flat pavemt and it keeps burning cluches out im 230lbs mabey that why??
teamhp is offline   Reply With Quote
Old 03-12-2008   #19
Re: Mudd Boggin'!!!
I have the same problem..no take off power. And I'm 160 lbs. I'm swapping out the rear sprocket 54t for a 72t or 78t. I know I'll lose a lot of top end, but I don't need to be blastin' down trails at 40mph.
MotoMonkey is offline   Reply With Quote
Old 03-12-2008   #20
Re: Mudd Boggin'!!!
I'm guessing your quads have the heavier 8mm chain and sprockets, if thats the case you need to swapout your sprockets and chain to the 25, I do that to all the new quads that I get because the 8mm is all wrong for these things, thats why you have no power, burning clutches, good top end, thats if you can get it to top out. I usually start out with stock gearing which is 6/68, but it depends on what size tire you have, I'm assuming if your mudbogging you have the bigger nobbie tire, if thats the case go with the 6/74, but what ever you do get rid of that 8mm setup, pinion, chain, and rear sprocket.
MGD$101 is online now   Reply With Quote
Page generated in 0.36279 seconds with 74 queries
