Hey...I just purchased a 110 atv and I am having trouble finding upgrades for it! Any ideas of what to upgrade first and where to get the parts? Anything will help....especially from someone that has one! Thanks- D
I'd personnaly start with an NGK spark plug C8HSA (a must), then a racing CDI and a good air filter. I would also put a magnetic oil drain bolt and change the chain for an O-ring one.
I will send you an MP with a website that has all these parts.
Thanks a ton! This really helped, will these parts make a big difference? I also read somewhere that you should upgrade to the super coil! Will the spark plug be enough or should i do the super coil? Im not sure of the cdi to get, but i think mine looks like this. Should I get this one?
You will feel an increase in RPM for sure, as for the super-coil I never tried it. THe coil you're looking at looks nice, especially if it's made with Japanese components.
You can also pick up a larger carb, it will raise the RPM even more (but you'll lose on acceleration a bit; larger carb=more rev, smaller carb=more torque).
