Pocket ATVs are on the way
47cc converted to 110cc
pics of your quads
LOOK AT THIS!!! gotta get it
49cc A4 Quatro Quad
Cobra S4 questions....
New quad --> Cobra S4
Old 10-14-2007
quad 110cc help!!
Hey...I just purchased a 110 atv and I am having trouble finding upgrades for it! Any ideas of what to upgrade first and where to get the parts? Anything will help....especially from someone that has one! Thanks- D
Here is the quad if it helps:
http://www.usaatvs.com/Detail.cfm?id=563
Old 10-14-2007
Mec Pocket's Avatar
Re: quad 110cc help!!
I'd personnaly start with an NGK spark plug C8HSA (a must), then a racing CDI and a good air filter. I would also put a magnetic oil drain bolt and change the chain for an O-ring one.
I will send you an MP with a website that has all these parts.
Old 10-15-2007
Thanks a ton! This really helped, will these parts make a big difference? I also read somewhere that you should upgrade to the super coil! Will the spark plug be enough or should i do the super coil? Im not sure of the cdi to get, but i think mine looks like this. Should I get this one?
http://www.scooterparts4less.com/web...oke_HP_CID.htm
Thanks again.....
Old 10-16-2007
Mec Pocket's Avatar
You will feel an increase in RPM for sure, as for the super-coil I never tried it. THe coil you're looking at looks nice, especially if it's made with Japanese components.
You can also pick up a larger carb, it will raise the RPM even more (but you'll lose on acceleration a bit; larger carb=more rev, smaller carb=more torque).
Hope this helps.
Page generated in 0.58813 seconds with 25 queries
