Pocket ATVs are on the way
pics of your quads
47cc converted to 110cc
LOOK AT THIS!!! gotta get it
49cc A4 Quatro Quad
Cobra S4 questions....
New quad --> Cobra S4
Old 11-18-2007
Quad just dies...
Ok, here's what happens...I get it started as soon as I give it a little gas it revs then dies...
I've checked the gas...emptied the tank and replaced with new gas..
I've changed the spark plug...
I've replaced the fuel lines and fuel filter...
the quad has roughly 10 hours on it and i am just ignorant to the workings of the engine...
does anyone have any ideas on what's going on?
on how to fix this issue??
Thanks!!
Old 11-19-2007
lkrace's Avatar
Re: Quad just dies...
2 stroke mini quad or ?
Old 11-19-2007
yeah, 2 stroke mini...sorry about missing that detail...
Old 11-19-2007
lkrace's Avatar
The rubber disc has probably turned or is torn in the fuel shutoff and is not flowing quick enough. Put a cup under the carb and pull the drain screw. See if the fuel flows freely.
Old 12-01-2007
take your fuel shutoff valve apart and clean all the gunk out, sometimes when it builds up, the fuel cant get through quickly enough or maybe what lkrace said. The rubber disk inside might be torn or not in right
Old 01-04-2008
Its either running to lean or rich. Possibly the carb also. Let me know if you need any other help or need a carb.
Old 06-24-2008
its your fuel shut off valve as soon as u turn them the first timee it breaks so take it off and take out the rubber disk and then try it it might help!!!!!!!!!!!!!!
Page generated in 0.32310 seconds with 33 queries
