hey hey i have a few of those motors plus a few inrunners too.
the outrunners have absolutely rediculous torque and that particular one in the scooter has a 8mm hardened shaft and some pretty decent size bearings to boot. id love to get that massive one one day.
just glue the magnets in with some microballoons as they like to drop off if you put the motor through some shock and its all great. im just putting one onto a stand up razor scooter myself. should be good
youll find the outrunners dont really heat up all that much either because they are so totally ventilated by design and by the outer ring spinning it pretty well dissappates its own heat. but sure a shaft driven fan could never go astray.
thats how the eteks are setup
good thing with the huge outrunners is that you *almost* get free power as you go up in voltage. just double the voltage double the gearing and it just wants to run cooler and hammer out more power
only problem is the controllers. the only one ive got is a 110 amp 36v one thats quite small but i guess you could get any number of controllers to go with it.
would love to chuck a pair of the big ones in a pocket bike find a decent controller and run them both at 60v
