Go Back   Pocket Bike Forum - Mini Bikes > Pocketbike Tech Talk > Electric Pocketbikes > EvPb 30+ club
ratbike(RAZOR-mod)
The Electric X9
Ex-Volt1500 (Worlds Fastest Microbike)
1000/1200 watt motors
Member Talk (Members Only)
Armando check this out!
MT44 project(ratbike 2)
The C1 electric conversion story
50mph etek-powered electric super bike
EvPB Logo
Old 01-03-2006
aureliencomte's Avatar
Re: The C1 electric conversion story
Thanks junny, I'm gonna put one of them under the seat, I haven't any other choice. But I have to manage with the controller which place is under the seat too... by the way I will have to hack the fairing, cause batteries are too large to fit this pocketbike and I prefer to mod the fairing (which is not so complicate and it wouldn't be so ugly ) rather than put smaller batteries and loose my range. Thanks for your interest man
  #22
Old 01-27-2006
So here we go... I received yestarday my brand new 55th sprocket and master links to fit it. Today I received the 3 brand new batteries. Just missing the motor and the throttle which would be here at the end of the week (yes I know we're friday lol)
Here is the new pics with the batteries, the brackets and the controller.
Have to make other brackets to lock out batteries and to really isolate them.
  #23
Old 01-28-2006
YEEEEEEEEEEEEEEEEEEEEEEEHHHHHHHAAAAAAAAAAAAAAAAAAA !!!!!!!!!!!
I received this morning my MY1020 750W Thanks a lot Chris from Tnc, and Mondo for your help
Here are the pics and.... dem look how it fits perfect to the C1 frame without any mods..........
I can't stand to have it running (but 5" height snow in France today sooooo....)
  #24
Old 01-28-2006
aproldan's Avatar
wow frenchie that is a perfect fit...sorry about the snow man.... maybe you can put some snow skies on the front tire and than test drive it... lol.......remember if you are unsure about anything let us know before you atempt it... that bike it going to fly brother... yeah baby
  #25
Old 01-29-2006
Ok Mondo, I remember we told this baby is CW and I need to know how to change it CCW. Moreover I looked the controller's website and the data sheet isn't not exactly the same as my controller. On my TSP I have 3 big prongs while there are 4 on the website. They're called : B+, B-, M-. Where is M+ The scheme on the website is easy to understand but what can I do with the motor leads ?
Thanks for your help, this baby is coming
PS: And this is my 55 tooth sprocket
  #26
Old 01-29-2006
This is my electric diagram, please fill in how I have to connect the motor and where I should put the circuit breaker ?
Thanks.......
  #27
Old 01-29-2006
And this is how my motor looks like inside.... What should I change to invert the rotation ?
  #28
Old 01-29-2006
aproldan's Avatar
ok the easiest way for now is to just to switch you motor wire around.. so the black on your motor will now be hooked up to the b+ on your controller and the redwire will now be hooked up to m- on your controller....... your battery run in series and hook up as normal negitive to b- and positive to b+....... on/off switch you wire from the battery to the small prong...i put some pics in so you can see...hope this clears everything up for you.... if you have any question let me know...
  #29
Old 01-30-2006
aproldan's Avatar
ok i posted too late you took to your motor apart....ok here is what you need to do ....put the motor back together lol... do you know how to put it back on ?????you will need to remove the coil from the casing... this mean now you need to take the sprocket off so you can remove the coil....the bolt holding the sprocket is reversed... you need to loosen it the opposite way you usually loosen a normal bolt...once the coil is out you need to tape off the brushes(tape just makes it easier to get the coil back on so you don't damage your brushes) put coil on then pull the tape off... brushes should sit back on... once that is done it is time to put the coil back in the casing... first put one hand in the casing( you need your hand in there to guide the coil back in)... if you don't do this then the magnets will pull the coil in hard and pop your brushes back out and you will have to start all over again...once you guide it thu put the motor bolts back on,, but turn it 90 degrees from where you took the bolts out from the first time....... that should put the rotation ccw..tighten the 2 bolts but not all the way..... you need to leave them just a little loose so you will be able to adjust the timing on the motor... use one of you batteries to test your motor to see if your motor is turning ccw...if you need me to take pics for you of each step, so you can see what it should look like, let me know..... i have big blue here and it's all apart so it would be easy to do ... let me know...
  #30
Old 01-30-2006
Ok Thank you Mondo, I did what you told me and the motor spin CCW now. Now everything is connected, but it don't works I don't understand why...Are you sure of your diagram ? On your pic we can see the blue wire from your motor is connected @ the M- and the brown @ the B+. Is your blue wire the black or the red one on my motor ? Then I put my circuit breaker between battery + and B+, the on/off switch as you said, the charging receptacle between battery + and battery -, and the throttle seems to be well connected... I don't know what to do I wonder if the controller works How can I be sure of it ?
  #31
Old 01-30-2006
Mondo, I was just wondering if you tried the controller before you sent it to me ? The one on the pic is mine ? So if you tried it it should work with the setup on the pic... On your diagram, you connect the motor + on the M- (so you invert polarity) and I saw that I can't change polarity now, because my motor is spinning CW since I changed it ! So should I connect motor- with M- and motor+ with B+ ? That seems to be logical but I don't want to make mistake so I will wait for your advice...
  #32
Old 01-30-2006
aproldan's Avatar
frenchie, sevo checked it before he shipped it to me.... and i checked it before i shipped it to you.... take a pic of your throttle hooked up to the controller ok ............street had the same problem and it end up being the throttle
  #33
Old 01-30-2006
aproldan's Avatar
yes frenchie since your motor now spins ccw all you need to do is connect red wire on your motor to b+ ........ m- to your black wire on your motor... that pic is of your controller... sevo took the pic of the set up before he packed it up and shipped it to me... and again i did check it to make sure it did work before i shipped it to you....once you get everything hooked up and working we still need to set the timing on the motor.... so when you get to that point i will walk you thru the timing adjustment.... are the colors on your throttle red/green/black????take a pic please so i can see what you are doing....thanks
i just notice something you wrote... the breaker goes from the battery+ to your on/off then the first small prong on the left....
  #34
Old 01-30-2006
YEEAAAAAAAAAAAAAAAAHHHHHHHHHHH IT WOOOOOOOOOOOOOOOOORKSSSSSSSSS
I took it for a short ride it's torqu-ey !!!!!!!!!!!
I will take pics of it but now should I take off the motor or just the cover to adjust the timing ?
  #35
Old 01-30-2006
aproldan's Avatar
just the cover bud glad you got it working
  #36
Old 01-30-2006
aproldan's Avatar
hey frenchie all you need to do is loosen the bolts to the motor just enough for you to be able to turn the back end got it ??does to bike feel like it wants to do a wheelie as soon as you hit the throttle??
  #37
Old 01-31-2006
yes, I must be careful with the throttle, if I pull a 'lil bit, it wheelies without any problem . But I think it could maybe hit a lil sooner. It weighs about 70lbs, and I can say 80% of it are before the pegs
  #38
Old 01-31-2006
Ladies and Gentlemen, please welcome................
The 1ST C1EP (Electric Powered)
Specs :
- Motor MY1020 750W - 36V
- Controller : 200amps
- Batteries : 3 x 12V12Ah
- Gear Ratio : 11 x 55 (to start with )
- Tire circumference : 35,75"
- Weight is about 72 Lbs
- Max Speed is actually about 20Mph...
And a lot of upgrades to come.... More pics soon
Special Thanks to : Mondo (Executive Director ), Street (the staff entertainer lol) and dealers who provided me all I needed : Tncscooters, Sevo, ....
  #39
Old 01-31-2006
aproldan's Avatar
LOOKING GOOD ....... are you ready to adjust the timing on your motor??????
so it will go faster and and take some of that wheelie power out of it.... take a video of you riding it... i want to see it in action baby...and send me your e-mail i'm going to send you a vid of my boy riding his bike.....
  #40
Old 02-01-2006
Sorry my modem was out of service. I've got a new one now. Your vids are great I'm ready to adjust the timing now, tell me what I need to do !!! If you need pics of my motor just ask me
What do I need to convert my gas C1 in electric ? aureliencomte Electric Pocketbikes 16 12-08-2005 04:35 PM
Fix Electric Pocket Bike Help! Please! PocketBikeRyda Electric Pocketbikes 7 05-25-2005 02:28 PM
C1 (2nd gen) vs polini (all polini) ;) Juan Luis Water Cooled Pocketbikes 35 05-03-2005 02:40 PM
My experience on C1 and GRC RR 8.5 John P Water Cooled Pocketbikes 6 02-23-2005 10:30 PM
Page generated in 1.16536 seconds with 75 queries
