Go Back   Pocket Bike Forum - Mini Bikes > Pocketbike Tech Talk > Electric Pocketbikes > EvPb 30+ club
ratbike(RAZOR-mod)
The Electric X9
Ex-Volt1500 (Worlds Fastest Microbike)
1000/1200 watt motors
Member Talk (Members Only)
Armando check this out!
MT44 project(ratbike 2)
The C1 electric conversion story
EvPB Logo
50mph etek-powered electric super bike
Old 11-11-2007
Smile do you need a 48v charger for a 48v battery?
When i upgrade my mx500 to 48v,will i need a new 48v charger or can i keep my old one?
Old 11-14-2007
Phil_G's Avatar
Re: do you need a 48v charger for a 48v battery?
Seems to be no-one around at the mo so I'll answer this one...
There are several ways of charging your batteries, the first is to be preferred:
1) buy a new 48 volt one with a similar specification for charge current as your 36v one
2) disconnect all 4 batteries, then parallel connect them for the duration of the charge, and use a high-current 12 volt car battery charger.
3) break your four batteries into two packs of two, ie 24 volts each, Parallel them for the charge and use a 24 volt charger.
4) Buy a dumb 13.8 volt power supply which MUST have an isolated output, ie neither pos or neg are connected to ground, and wire this in series with the output of your 36 volt charger. Choose one that gives at least as much current as your 36v one. More is ok, the 36v one will limit the current.
5) wire a charged leisure battery in series with the output of your 36 volt charger. Make sure you dont discharge it anywhere near fully though.
Cheers
Phil
PS given the nature of the question, maybe I'd better emphasise that in adding a psu or battery in series with the existing charger, you're wiring charger neg to bike neg, charger pos to psu neg, psu pos to bike pos. Dont get it wrong!
Old 11-14-2007
Cheers
Phil
cool! thanks for the advice
Page generated in 0.23806 seconds with 21 queries
