Custom paint job pic thread
best color for a pocket bike
painting tommarow
my paint job what u think ??
Pictures of my X18
What do you call your bike
Old 05-05-2008
krylon fusion paint?
ok.. im am quite confused it says on the can no sanding and no primer? so i dont need to primer it if i use that paint?
Old 05-05-2008
Re: krylon fusion paint?
but on that sticky thread it says to sand it then use the krylon fusion paint
Old 05-07-2008
sr20hardbody's Avatar
yes sand it dont use primer its not necessary. fusion was mostly made for plastic cuz it actually chemically bonds to the plastic but can be used for everything else too except vinyl or leather type stuff.
just make sure your surface is stripped of all oil and dirt and the temp is 70 degrees or higher. the higher the heat the faster it'll cure and the stronger it will be. use krylon clear coat 7 days after you fusion something that way its gaurenteed not to scratch easily. its not gas proof though gas will take it off only engine enamel or powdercoat stands up to gas but even then it'll still discolor so dont spill any gas!
follow the directions on the can and use very very light coats on the first couple coats then go heavy but not to where it drips.
Old 05-07-2008
ok thank u
Old 05-31-2008
I just painted my x18 using Krylon Fusion.
SANDING IS A MUST!
Take your time,apply many thin/even coats,then finish it off with 3-4 coats of clear..Let dry for 24hrs,and your golden.
Old 06-02-2008
734irish's Avatar
what grain paper has worked best for ya'll? thanks
Old 07-14-2008
X19rider's Avatar
I would use 400-600
Page generated in 0.33742 seconds with 34 queries
