| Re: marble paint I know how to paint marble. tools needed are primer, base coat paint(your choice Silver or gold) and transparent candy paint and clear coat. First you primer the parts and make sure all the body work is done. Second you spray the parts with the base coat. Once the base coat is dry. you spray black on the parts. Wrap the parts in saran wrap and the peel off and let dry. repeat until you achieve the desired look. Wet sand the parts with really fine sand paper. Once the roughness is smoothened enough. It's time to spray the transparent candy color. Scuff the paint with a scotch brite pad and then shoot the clear coat. |
