Custom paint job pic thread
best color for a pocket bike
painting tommarow
my paint job what u think ??
Pictures of my X18
What do you call your bike
Old 05-08-2007
001Versace's Avatar
Exclamation Warning about Neons and Cold Cathodes
Be very careful. They are like those house lights with the tube that go on the ceiling. Florensic Light is it?
My cold cathodes broke! I was riding on a bumpy surface, and my neons are always sealed good. I look back, inside of the tube is all cracked into like glass.
Careful installing these on cags because of the 2 stroke loudness and vibration, it may cause some damage.
Old 05-08-2007
nofearX18's Avatar
Re: Warning about Neons and Cold Cathodes
i want something i dont have to run off my batt cuz well my batt isnt installed lol.
what would work off AA batterys or something?
Old 05-09-2007
l.e.d.s,,,,easy to fit easy to wire upto a small AA pack
and all they need are a few drill holes,,,job done lol
Old 05-09-2007
49ccGSXRbike's Avatar
where can i find led neon lights..and a blue/white HID headlight...and x18 clear corners for the front turn signals....thanks
Old 05-09-2007
hi i use a 9volt battrie one of the small square ones works fine
Old 05-09-2007
nofearX18's Avatar
i was thinkin about tht tusker. wasnt sure tho. thanks!
49... i think u will have to make a clear thing for the turn signals your self...
Old 05-09-2007
k...but what about the led neon and hid headlight
Old 05-09-2007
Yeah, I actually want the same thing. I was thinking about buying PC LED's, and rewireing it to work on a off-on switch powered by a 2 AA batteries. Not excally sure how i would do that, but i have a few friends who are smart.
  #9
Old 02-14-2008
you could put in a altinator to power the lights and the put a bunch of capacitors with it so it doesn't dim and brighten when you twist the throttle
  #10
Old 07-03-2008
Ultramang's Avatar
L.E.D s work really good, i use LED on my bike, i have headlight,neon,engine light, dash light, ground lights, and tail lights.
  #11
Old 07-12-2008
X19rider's Avatar
hey would it be good to use a l.e.d. neon strip? heres the url,
Pocket Bikes Unlimited Accessories
  #12
Old 07-12-2008
Ultramang's Avatar
whoa i never heard of those haha, theywould probably work good. id say it would be better than what i have haha =D
  #13
Old 07-14-2008
SpyGuy's Avatar
^^^ Ummmmmmm, yeah ......
Sorry, amigo, but not a lot of us on here can read Chinese (Japanese? What is that?). Would you mind please reposting it in English? Thanks.
  #14
Old 07-14-2008
FRP firemen equipped with high-quality resin and glass fibers from the carpet, fire equipment (fire extinguishers, water zone) for the storage bins. Steel glass of water with me is the fire dragon with a dedicated storage bins used glass steel production, corrosion resistance, weatherability good, not rusty, Mei Lan, a disc into the water with me-and-water Diskless with me. Foam guns, air-bubble guns, hand-held air bubble gun PQ8.C portable air-bubble guns, according to "the level of steel ship-building norms," the fire called for in the design and manufacture products, ship and the People's Republic of China Inspection Bureau Nanjing Branch of qualified inspection, the product is air, water, bubble jet carried out by three of its own hybrid produced by the mixture of substances used to fight oil fires, can spray water to fight the fire generally solid material. Respirator main specifications (0.25-0.7 MPa) range ≥ 15 m of the bubble: 1.5M3/min mixture of: 400 L / min water: 400 L / min bubble liquid drum capacity: 20 L YE3, YE6 protein bubbles of air bubble gun fire Use of foam fire extinguishing agent is the animal protein hydrolysis concentrated liquid-based materials, and contains the appropriate stability, anti-corrosion, antifreeze, and other additives composed of foaming liquid. The fire extinguishing agent widely applied to petrochemical companies, oil fields, oil depots, oil terminals, ships, and fire brigade, you can have a variety of low multiples of foam and water equipment in accordance with the ratio of three ninety-seven or six ninety-four mix and A bubble, mainly used to fight the blaze General non-water-soluble (oil) of flammable and combustible liquid fire, can also be used to put out the fire generally solid material. The fire extinguishing agent should be stored in sealed room cool, dry, ventilation, temperature of -5 ℃ ~ 40 ℃ environment, valid for 2002.
  #15
Old 07-14-2008
Ultramang's Avatar
lol, im chinese but i cant read that =P
Page generated in 0.65129 seconds with 58 queries
