Originally Posted by Ricky25 like its has either no gaskets or bad ones. but it started for me a couple times. and it was intermediate to pull had spark and compression. i dont no how much compression is supposed to be. but i know it started once or twice and now it wont so i thought someone could help. its a 49cc 2 stroke.. if that helps. also when it leaks oil what can i do to fix it?...let me know everything i can do besides buy a new motor |
if you know it has bad gaskets then i suggest you change all of them, buying a full gasket set for these bikes isn't that expensive. a bad gasket can lead to a intake manifold leak to low compression in the pistons causing it not to start.
when your trying to start this thing are you setting the choke to closed? and twisting the throttle to give it some gas? you mentioned a oil leak, where is it leaking from?
